Results 1 to 6 of 6
Thread: Welding on my 2.5?
11-26-2002, 08:09 PM #1
Welding on my 2.5?
I need to do some welding on my block. I need to find out if I should remove any or all the electronics(stator, power packs, etc.) before I do so.
Thanks,
vamp
11-26-2002, 08:24 PM #2
It definitely would not be a bad idea. I know for a fact it will take out an ECU.
11-26-2002, 08:42 PM #35000 RPM
- Nov 2002
- Levelland Tx
- 106
ya
Ya I would go ahead like us1 says. That stuff is way expensive to just hope for the best... What are you gonna weld?
11-26-2002, 08:53 PM #4
2 studs
My torque wrench must be out of calibration. I must have tightened the 2 studs holding the power head to the exhaust plate to tight and cracked the block in them areas.
Thanks,
Vamp
11-26-2002, 08:53 PM #55000 RPM
- Aug 2002
- Morristown Tn.
- 164
welding
Electronics are my living, another vote yes remove them. It can only save you money. Bob
11-26-2002, 08:59 PM #6
If it’s the two studs in the back it is from not tightening in the right order. Always tighten the middle first then the front and the back last.
