Results 1 to 4 of 4
08-11-2011, 11:25 PM #1Member
- Nov 2004
- Houma, Louisiana
- 80
2.4, 2.5 liter fishing lower unit into a 3.0 torque master lower unit
Can anybody tell me if the parts from a 2.5, 2.4 fishing lower unit can fit in a 3.0 torquemaster lower unit? I'm tring to convert a counter rotating torque master into a right handed lower unit. I can't seem to find good priced parts for the torque master or just parts at all used. I do have parts from a 2.5 and a 2.4 lower unit. I do know a 3.0 bearing carrier will fit in the 2.4, 2.5 lower units but not sure about the gears and shafts going in the 3.0 off a 2.4 and 2.5.
08-12-2011, 03:12 PM #2Member
- Nov 2004
- Houma, Louisiana
- 80
needing info please
Does anybody know about this?
08-12-2011, 09:29 PM #35000 RPM
- Nov 2005
- NE Alabama - Weiss Lake
- 702
- 7
I dont know the answer to your question but if you go to mercruiserparts.com and look up the various part numbers for the 2 lower units innards you can see if any parts #'s match up. I suspect not as the Sporty is the 19 spline fat shaft and the 2.4/5 lowers are the 15 spline prop shaft.
TJ309
Older 17 foot Laser / 2.5L Merc 245 Racer
1993 Speedster 13 / 2019 Merc 60 play boat
2020 Lowe 24' Pontoon boat / 250hp Merc. 51mph!
72 Hydrodyne bubbledeck undergoing keel up restoration
2 Jetski's
08-12-2011, 09:51 PM #4Member
- Nov 2004
- Houma, Louisiana
- 80
The counter rotation torque master came with a LH fat shaft. I have a RH fat shaft that i was going to use but I can't seem to find good used gears for it. I heard the fat shafts can be taken out and 2.5 shafts can be put in place. i'll go take a look at mercruiser and see what it says.
