Results 1 to 11 of 11
Thread: AE-21 help
    Jul 2011
    canada
    AE-21 help
    picked up a 89 AE-21 with a 91 225 Yamaha,boat looks great and is solid,drove around ,great ride and feel,couple of questions?
    top speed is 74 mph gps and 5500 rpm,is that right?
    - has a 26 p chopper prop
    - what is max rpm on that engine?
    -it has dual cable steering,was thinking on a Hydrolic system?Click image for larger version.
ID:	240110Click image for larger version.
ID:	240111Click image for larger version.
    Nov 2003
    Simi Valley, SoCal
    Looks nice! I looked up the gear ratio on the Yamaha and it showed 1.81:1. If that is correct, at 5500 with a 26p if you are getting 74mph, your slip would be 1%. That is not possable so since you said GPS speed we should be able to trust that. Check your lower ratio by putting it in gear, marking the prop position and turning the flywheel to see if it is 1.8 turns to make 1 turn on the prop. If that is correct then your prop has been pitched up or your tach is reading low. Hydraulic steering reduces the torque steer and is much smoother. It's not cheap but once you have had a boat with it it is hard to go back to cable.
    Here is what I found on that engine:
    Motor Specs
    Manufacturer: Yamaha
    Year: 1991
    Horsepower: 225.0
    Cylinders: 6
    Type: 2 stroke
    Gear Ratio: 1.81:1
    Min WOT RPM: 5000
    Max WOT RPM: 6000
    Spline Count: 15
    Drive Type: Outboard
    96 Cougar 23 MTR twin 300XS's. 100 something
    98 Laveycraft Sebring 20.2 Tunnel 280 90 something SOLD
    85 Baker RST 220 Laser SOLD
    JUPITER, FLORIDA
    I'm running a 1991 AE-21 with a Merc 2.5/200, 12" of setback, hyd. jackplate,CLE gearcase, Tempest Plus 25 into the 80's on GPS. You should be able to get more than 5500 rpm out of that motor. What's your propshaft height compared to the pad?? How much setback are you running. The AE-21/HST bottoms like to run flat; they don't require alot of trim. Feel free to contact me anytime. I'm still dialing in my AE-21!! Steve
    Attached Thumbnails Attached Thumbnails AE21 MAIDEN VOYAGE 001.jpg   AE21 MAIDEN VOYAGE 003.jpg
    J-Town Hot Boat Team
    Barracuda 188CCR/Suzuki 140
    Past Boats:
    Checkmate 2800SX/Twin Merc 250’s
    Checkmate Pulsare 2400/Verado 300
    Checkmate Starflite/Merc Pro XB250
    Canadian Edition Hydrostream AE-21/Merc 2.5
    Checkmate Pulsare 2100/Merc 225Xri
    Hydrostream Valero YT Bowrider/Merc 175
    Talon T-21/Mercury Racing 2.5 Carb
    Sleekcraft ModVP Bowrider/Evinrude 225 Vindicator
    Velocity 230/Mercury 454 Magnum
    Scout 172 Sportfish/Yamaha 130
    SeaRay F16 Jet boat/Mercury SportJet
    SeaRay 17' Seville/Merc I/O
    JUPITER, FLORIDA
    Apexfx, I was just reviewing your pictures. You need more setback and a hyd. jackplate. Adding hyd. steering would also be nice but do it after you increase your setback so you'll know what length hoses you'll need for the hyd. steering. With more motor height and setback you'll be able to get more RPM's out of the Yamaha and pick up top end speed.
    Past Boats:
    Sep 2002
    Parry Sound, On
    I would think you're going to need a nosecone/low water pickup before you start raising that motor too far. The gear ratio should be a 1.86:1 and if you cut the limiter they'll pull pretty good until about 6500 in stock form. Those motors were also designed to run premium fuel...
    '08 SRV
    Yamaha 3.1 Phase III
    JUPITER, FLORIDA
    Quote Originally Posted by DoktorC View Post
    Yup, DoktorC is correct..you'll need a nose cone with low water pickups to retain water pressure at higher motor heights.
    Past Boats:
    Winnipeg
    Nice purchase, pretty sure that boat has extremely low hours. Where are you going to run it?
    As mentioned, it probably has another 10 mph in set up in it.
    I believe there are a few owners on www.fastboatscanada.com too. Might be worth joining.
    Allison XB02, 22ft Tritoon 225 4 stroke, two seadoo sparks
    Past rides 2001 STV EURO, Allison Grandsport, STV RiverRocket, STV Euro, STV ProComp, Hydrostream V-King
    RIP RPM RACING
    RIP GTS1
    Kansas
    I thought the 2.6L Carb 225's did have the 1.81:1 ratio (?) I don't think they have to have premium either. This was just a bass motor (actually, it didn't even get the louvered cowl, mounts and "Pro V" badging) so it wasn't even touted as a "bass" motor. Put some HT 8200 heads on her and she will need some premium. :-)
    Allison XB2002 Comp Pro / 2.6L Yamaha 200 VMAX TRP
    Sep 2002
    Parry Sound, On
    Quote Originally Posted by DarthVMAX View Post
    Darth...this was the top of the line back then. The 225 evolved from the Excel and had the second generation computer controlled ignition. It has more agressive porting and staggered compression over the ProV...along with the fact that it was a horizontal reed motor versus a vertical reed. They basically got all the best 2.6 parts.
    They are 1.86:1 and they do run best on premium...they don't HAVE to have it because of the knock sensor but it'll pull timing and you'll loose performance. The HydroTec heads are probably a waste with that ignition since it'll probably start pulling timing unless you dump a TON of fuel in it.
    The motor under the HPDI cowling in my signature picture is the same motor (but it's a 1990)....
    Darth how do you like the TRP lower??? I've got one but never tried it...
    '08 SRV
    North Branch & Pine City, Mn.
    Great purchase. Love the AE's. I agree that more setback will eventually help, but for sure with a cone and LWP. I'm running 15" of setback on my HST. Don't try to run a ton of motor height and a lot of positive trim without more setback though. I found out the hard way on my Venus/Yamaha 200 that it will run the lower hot and cook seals, and filler. Also, open up the water scoop and passage from the cavitation plate to the mid to get it to run cooler. Let me know if you have any questions, I had a heck of a time finding this out.
    The Reverend, (Cedar Machine Service on Facebook)
    1989 HST 2.5 260 Merc Offshore
    1991 Vaserette YT 200 Mercury
    1988 Venus XT 200 Yamaha
    1983 Viper II Merc 90
    1977 Viper
    Mini GT tunnel, 25 Merc
    "African Queen" pontoon 25 Merc
    Aluma fishin tub, 20 motors to choose from!
    GUESS WHAT?...I gotta fever,...and the only prescription...IS MORE COWBELL!!
    Jan 2005
    florence s.c.
    Jupiter Pulsare
    You hit the nail on the head!!! They like to run flat!!!! Gotta get that motor height right, and have neutral trim at top end... I was amazed at how my HST felt like it caught second gear at about 90-95,,, and then it quickly got over 100!!!! I had 18" setback!!!!! What!!!!!! Balzy helped me out a lot with my setup...107 was the best with little setup time... A lot of people told me I would never get it over 100...... I showed em on the gps!!!!
