Results 1 to 3 of 3
Thread: Trailer Brakes
08-08-2011, 09:51 PM #15000 RPM
- Sep 2008
- Delaware River,NJ
- 354
Trailer Brakes
At what total weight, boat, motor and trailer should you be using brakes?
Mine kept locking up (drum brakes single axle) so they are removed for now and I don't notice much difference
Nj law is 3000 lbs.
08-09-2011, 06:38 AM #2
Each state has its own laws, but it also depends on your tow vehicle. BTW, I have been using drum brakes for years. I have a flushing system that pipes fresh water into the backing plates. Works real well as long as you use it, and use it soon as possible after launching or retrieving. Been thinking about putting an old fuel tank on the tongue of my deck boat trailer to fill with water and plumb into the flush system, so I can drain it into the brakes at the ramp when I don't have access to a hose.
I know lots of you like disc brakes, but I have seen them lock up internally. And you need a lock-out to back them up.18 Talon/2.4 carb SOLD
26 Deck Boat/250 Merc
08-18-2011, 08:07 AM #38000 RPM
- Sep 2006
- not here
- 3,376
- 204
- 423
- 389
- 693
I would go to 1500 lbs without brakes. Coming from experience, there is nothing like having good brakes on your trailer when you have to make a panic stop on the freeway. I like disc brakes because all components are exposed for easy inspection. Mine have been trouble free for 9 seasons now. Flush the fluid every 4 years. They do not see salt water.
'03 21ft Inboard skiboat V-8
'70 14ft Winner, 90hp Merc
'22 21ft Inboard skiboat electric
