Results 1 to 11 of 11
    Mar 2005
    North Mississippi
    Exclamation Broken sportmaster drive shaft....HELP
    I have a 3.0 liter sporty with a broken drive shaft right above the pinion gear. How in the heck do you get the pinion nut off so I can get the prop shaft out?????
    HP(frequent flyer)
    Jul 2002
    FT WORTH, TEXAS
    Fix
    i get them once in a while like that nothing to it i weld a1/2 bolt to the stub of the drive shaft then proceed Good luck
    Jul 2002
    FT WORTH, TEXAS
    The Fix
    i get them once in a while like that nothing to it. I weld a 1/2" bolt to the stub of the drive shaft then proceed Good luck
    Nov 2003
    Simi Valley, SoCal
    You should be able to wedge something between the pinion and fwd gear teeth. I would use a piece of hard plastic like nylon or delren.
    96 Cougar 23 MTR twin 300XS's. 100 something
    98 Laveycraft Sebring 20.2 Tunnel 280 90 something SOLD
    85 Baker RST 220 Laser SOLD
    Mar 2005
    North Mississippi
    It is broken right at the pinion.....
    I would be welding the bolt inside the gearcase. I'm not real comfortable with that either....what about the heat? One idea I had was to split the pinion nut with an air chisel on each side. I'm not sold with that either...
    There used to be a guy on this board that I think worked for Mercury. He may have lived in Florida but I can't remember. He was the goto guy with Sporty's and had a really quick turn arround time. Maybe Greg can remember whom he was........I'm stuck I now that for sure
    HP(frequent flyer)
    Oct 2010
    Harrisburg,Pa
    Here's a thought, can you take the spring off clutch dog and slide pin out and move it so it has room to come down. How much driveshaft is left on it?
    Sep 2008
    Treasure Island Fl
    Quote Originally Posted by HP View Post
    Craig Collabella. He is the man with gearcases. Worked at lake x for many years. Shop is in kissimmee fl. 407 498 0094
    Cawley
    Jul 2002
    FT WORTH, TEXAS
    where did it break in the small dia. where the pinion sets or somewhere in the fat part of the shaft below the top bearing
    Jul 2002
    FT WORTH, TEXAS
    im sure you have the prop shaft out correct
    Jul 2002
    FT WORTH, TEXAS
    its almost impossible to cut the nut with an air chisel i tried that more then once due to the recess of the pinion you can cut some of it but its dangerous because your working so close to the oring sealing surface for the carrier if you knock a chip out of that its over no more good seal there been to that dance also
    Mar 2005
    North Mississippi
    Texas the pinion had to come out in order for the prop shaft to be removed. After closer inspection the drive shaft broke about an inch down inside the pinion. After that the pinion nut welded itself to the broken part of the driveshaft by rubbing against the clutch dog. I don't think I could have ever removed the nut. A friend of mine helped me and I finally got the pinion out. I appreciate everyones comeback on this one. Thats what this board is all about.
    HP(frequent flyer)
