Results 1 to 8 of 8
    Sep 2002
    Kitchener On canada
    efi fuel return line help
    Hello. is it possible to have the fuel return line plumbed
    to a tee fitting just before the efi pump?
    I have 2 fuel tanks and want to have one return.
    Cheers,
    I also was wandering can it return to the tank vent tube..Just a thought also..
    Jun 2004
    Pelican Lake, WI
    I return into water seperator/fuel filter.
    Jul 2009
    new iberia, la
    Quote Originally Posted by hydrostreamvking4m View Post
    Thats how i ran my return line. I just connected it to the tank vent fitting. No problems. Knock on wood lol
    Sep 2002
    Kitchener On canada
    Thank you for the replies.
    I had it returned to one tank.
    i removed the fuel gauge and made it the vent.
    i attached the fuel return to the old vent (added an aluminum down tube).
    as there are 2 tanks with a selector valve i realized that (duh) that one tank would be emptying
    and the other filling.
    I moved the return to a "T" fitting after the selector valve before the filters.
    after that i notice some turbulence in the filters?
    The rig has never been in the water.
    I guess it is time to water test it. lol
    Nov 2003
    Simi Valley, SoCal
    There are valves that switch the feed as well as the return. Common on EFI trucks.
    http://www.oreillyauto.com/site/c/de...2000&ppt=C0025
    96 Cougar 23 MTR twin 300XS's. 100 something
    98 Laveycraft Sebring 20.2 Tunnel 280 90 something SOLD
    85 Baker RST 220 Laser SOLD
    Sep 2002
    Kitchener On canada
    Thanks!
    Aug 2005
    Stockton, California
    I have a 2.4 bridgeport and I have an electric tank valve to switch from the dash each tank. I bought the same valve for the return line and installed a switch up front. When I am on the the right tank i am on the right return side so fuel goes back into the water separator on the right tank.. Each tank has it's own separator so each tank has a return line plumbed to it..This works perfectly and I don't have to get out of the chair to do anything..Works great when you are racing, low on fuel run out and switch both switches over to barely miss a beat...hope that helps....
