Results 1 to 11 of 11
    Mar 2002
    Seaford NY
    Head torque on 4cyl mercruiser 488 the one with the ford BB head
    Two of my books show 130 foot pounds that seems really tight . If I remember right the head is cast iron and the block is aluminum . checking this for a friend that blew a head gasket. Have never worked on this engine so I figured I'd ask.
    Thanks
    jon b
    Hopedale, IL
    130 isnt all that much unless it is an aluminum block (which I kinda doubt). Are you sure it's not an aluminum head with a cast block?
    Sunsation 32 Dominator - 496 MAG HOs
    Nothing runs like a Deere when a CAT's on it's ASS!
    Florida Keys
    Yea not sure if the block is aluminum - I torque my 460 heads in my mustang to 140 (iron head iron block)
    '95 STV "The Blue Goose"
    Mar 2009
    Tulsa,Ok
    Believe the torque spec, is the Ford Spec
    Ft. Lauderdale, Fl
    Yes, 130 is correct, and yes, it's an iron head and aluminum block.....
    Hopedale, IL
    That's f'ed up
    Ft. Lauderdale, Fl
    Quote Originally Posted by njj502 View Post
    That's f'ed up
    Except for having an alternator proble, they were actually a good motor...........
    Mar 2009
    Tulsa,Ok
    Freind had one ditched the alternator on the harmonic balancer, used a single wire marine alt, made a bracket, also shucked the heat exchanger, and ran fresh water cooling.
    8 Post(s)
    the engine would have been a success if they used a chev head
    The ports in the ford were too big
    they also used a prestolite starter and that curse of a ford in a boat struck twice
    Miami,Fl
    They made an alternator kit but it was hard to beat the 140 iron duke engine. Rick
    Mar 2009
    Tulsa,Ok
    Have an Iron Duke in a 17' Checkmate, runs great, Mercruiser drive. Balanced the assembly and it is a seaing machine, 77' model.
    Ski Nautique guys get pissed because it will outrun their 351 Fords
