Results 1 to 2 of 2
    Apr 2002
    Question 1984 2.4 firing left bank only
    Didn't use last year. First time out this year, and this is what I found. Last when started cold, would stall as if running out of full / loss of power, but ran great all day long once warmed up.
    I switched the stator wires to see if it made a difference, but it did not start when this was done.
    If there is a thread detailing how to troubleshoot ie checking amperages of stator, checking functioning of powerpacks, .. I would appreciate getting the link.
    I'm sure this has been discussed a million times already, so I don't mind doing the work now, and asking for help if needed.
    Thanks.
    Jul 2002
    FT WORTH, TEXAS
    switched stator wires on the switch boxs? if so that the problem one of the switch boxs is out its customary to change them both .The Key its only firing 3, each box fires only 3 front box with yellow tape fires 246 rear box fires 123 also Left bank ? looking from front or rear??? its looking from the front right is port bank and starboard bank left side of motor
