Results 1 to 7 of 7
    Dec 2009
    Fl.
    2.5 midsection ?
    I have a 2.5 mid that has a tuner an the can removed , , an I seen that mercury offer's a block off plate to keep ext from going threw the lower unit , an Im going to drill out the mid to make it like a vp mod, , any thought on the pro's an con's of the block off plate ?
    Jul 2009
    Treasure Island, FL.
    Get an offshore mid instead
    27 Ft Fountain SF
    Twin Merc 250 EFI's
    Block off plate? Are you talking about a block off plate on an offshore to block off flow thru the rear snout?
    I know of no such block off plate to remove exhaust flow thru the carrier.
    FYI: I tested that when I was drag racing and it didn't work. The prop MUST have the exhaust bubbles to relieve the engine of the total prop load. A prop that has NO exhaust flow venting it cannot be turned easily even with a Drag motor..
    Good luck,
    Jay
    Jay @ JSRE
    Chackbay,La
    pics. would help.. because that doesnt make to much sense... No tuner??
    Dec 2009
    Fl.
    Monday when i get to work I will post part number an i pic of it , basically you remove the lower unit an it bolts in place here the can comes threw , an yes I also have Question about running an off shore mid , I have a Vking yt an want to know if i can run a 15 inch off shore mid?
    Dec 2009
    Fl.
    Bay Area , I have a tuner , i read what I posted an it confused me too , LOL , There is no can I removed it an installed a tunner.
    Jul 2009
    Here is a pic of aClick image for larger version.
ID:	236823 15in mid on a hydrostream vegas
    27 Ft Fountain SF
    Twin Merc 250 EFI's
