Page 3 of 3 FirstFirst 1 2 3
Results 31 to 38 of 38
  1. #31
    Jan 2006
    Ruskin, FL
    Quote Originally Posted by gfinch View Post
    kimswang I still have a MAD EFI system, well Dave has it. The what I found was MAD, is great for a drag boat, but only fair for a lake boat. There just isn't enough adjustment in it. It's 2D not 3D like the ViPec and other systems spoken about here.
    Interesting, very interesting. Thanks for the info. I will still run my V8's with carbs for the next couple of seasons but then replace all three engines (or rebuild). I have watched with keen interest the articles written about the FI aftermarket systems and not once have I found a real test on a V8. Not once a comparison to the new engines. Maybe the technology and interest just ain't there, but I would love to see a system developed and found functional for a OMC V8, running around 6K. There should be no problem to get 450-600 HP out of it with proper fuel delivery and electronic ignition. I love my old V8's but so does the gas station owner.....
    True Viking
    Scarab 34 SS with Triple OMC 4.0 V8's
  2. #32
    Jun 2010
    Rotorua New Zealand
    Quote Originally Posted by kimswang View Post
    Kimswang, I'm with you on this one. I have a Johnson 1990 V8 300hp which I plan to bracket mount on the stern of a Wellcraft Nova XL230. If I like the setup I then plan to purchase a second 300 V8 in the US and give it to Monty to recon/mod up to around 400hp. I would also like him to fit EFI to it then send it back to me in New Zealand.
    Last I heard Tony Brucatto was about to release an EFI system specially for the V8. After reading the write up on his OMC V6 EFI I for one would like to wait for his gear. Has anyone heard how far away his system is??????
  3. #33
    8 Post(s)
    If for fuel only, are any of the systems simple enough to just take crank sense from the ignition system and the rest is a bolt on so all you need to do is the fuel map?
  4. #34
    Jan 2003
    aalsmeer
    that,s not entirly the case since you can play with load/fuel values to Rpm/fuel values you can make a 3D map
    http://home.tiscali.nl/ronniestoys/D...sdsrevised.xls
    as opposed to the indeed 2D setup as it is mostly used
    http://home.tiscali.nl/ronniestoys/Data/Mad3ltrsds.xls
    Attached Thumbnails Attached Thumbnails Schermafdruk-62.jpg   Schermafdruk-61.jpg
  5. #35
    Jun 2004
    port st. lucie, fl
    you guys should email gordon, i know he was working on something
  6. #36
    May 2005
    Greenville, NC
    Quote Originally Posted by Smoking Joe View Post
    Tony told me he is not making any more kits. You might want to give him a call.
    Ló fasz racing
    Joe Horvath
  7. #37
    Trussvegas
    I'll second this since I own that engine.
    What does that sucker run like? It looks wicked as all get out on the video.
  8. #38
    Sep 2002
    Solvang, Calif
    Quote Originally Posted by Lockjaw View Post
    It runs good. I've got the trim working better now.
    http://youtu.be/xuV5dBiTWdI
    Gary
