Results 1 to 11 of 11
    Apr 2008
    Malta
    300x Engine Power Limited
    I have an intermittent problem on my 2002 300x and would like your technical advise to enlighten me on this matter.
    Problem is occurring in 2 different situations:
    1. At WOT engine only turns 5000 rpm, you can feel that the power is limited but nothing is recorded on smart craft.
    2. At WOT engine turns 6200rpm (seems to be OK), but suddenly smart craft displays "engine power limited" and sounds a continuous beep, guardian kicks in and the outboard idles. If you put the engine to neutral, then into gear to try to continue, the same things happens after 30 secs.
    Please note that the temperature is 118-120F, water pressure is ok, I'm not going into the rev limiter and the oil reservoir is full. Strangely enough, during testing I managed to simulate 1 and 2 (above) and as well get the full power out of the engine, all during the same day within 30 mins. Problem 2 is happening more frequently, but again, I might go out again and it works fine with full power for another 20min or so.
    Do you have any idea what this could be, is it worth trying a new MAP or TPI sensor or they have nothing to do with this?
    Your help is much appreciated!
    Thanks!
    Jan 2006
    If you have a DDT, scan the motor and write down everything. Then clear the fault history and fault codes and go run it until it acts up and see what came back on the DDT. Anything that throws an alarm will leave a code.
    Mar 2011
    Carrollton VA
    Consult th Merc tech manual
    Mercules is correct. if you check the Fault seconds on your DDT you should see the parameter that is exceeded. Only certain parameters will result in a engine gaurdian condition (don't remember). Check the manual. You can also see TPI, Map, Temp ...while running the engine with the data monitor and see the actual operating ranges in the Eng specs menu. By the sound of things you probably have a fault (in lieu of a bad ECU)because some faults will allow the engine to contiue for a short period then gaurdian kicks in. Good luck and keep us posted.
    Mark
    Apr 2008
    Malta
    Thanks to all for your instant replies!
    Manual says continuous beep could be:
    1. over heat
    2. over speed
    3. over heat cylinder head
    4. throttle sensor failure (continuous intermittent beep)
    On the System View SC5000 the alert history recorded "over speed" but this is impossible since I'm only turning about 6000. I will also try the DDT as Mercules recommended to look for other faults.
    Apr 2008
    Malta
    Hi, here is the data from the DDT.
    Freeze Frame Buffers (2 errors: Guardian and Overspeed)
    DATA RECORDED GUARDIAN OVERSPEED
    Baro PSI 14.9 14.9
    Batt Volts 13.8 13.9
    Block PSI 2.4 12.3
    Boat Speed 1.6 1.6
    Air Temp 89.6 89.6
    Cool Temp 117 115
    Demand % 100 2.5
    Engine RPM 6041 2583
    Engine State Run Run
    FPC Total 1.1 0.4
    Freq Counter 10 255
    Shift In Gear In Gear
    Sea Temp F -29 -29
    Load % 100 2.5%
    Mprly Req 1040 1040
    Map PSI 14.6 11.2
    Oil Level 30.2 30.2
    Port Tab Pos 0.0 0.0
    Avail Power 60 100
    TPI % 100 2.5
    Cool Temp Stb F 115 113
    Cool Temp Prt F 113 111
    FAULT HISTORY (SECONDS)
    Block PSI Low 11
    Guardian 125
    Overspeed 11
    All the rest have 0 values
    Any ideas, thanks in advance!!
    Apr 2008
    Malta
    Any ideas please!!?
    Are these values normal, block psi, fpc total and freq counter?
    Apr 2007
    Davenport Iowa
    I had similar problems with my 300x and had dealerships use their ddt to find nothing. Watch your water pressure(closely) and see what it reads exactly the time it goes into guardian mode. If it drops below 4.5 psi on the smartcraft, it will shut down. Try lowering the motor 1/4 inch or so and see if problem is still there.
    T-bone
    T-BONE
    Apr 2008
    Malta
    T-Bone so is the block psi related to the ecu limiting power?
    I've just went boating and noticed that the block psi is constantly 1 to 2, which is below the acceptable level. Water flow is fine and the engine is not overheating. Still at around 4500 revs the guardian is kicking in with a continuous beep and 2 alerts - engine power limited and overspeed.
    I've also changed the TPI and MAP sensors just in case, although I can now confirm they aren't the issue! Next in line is the block psi sensor but I would like to confirm if low pressure is related to the guardian limiting revs (overspeed). This is not explained in the manual.
    thanks
    Jul 2007
    Hamilton Ohio
    This may or may not help, but I've just had Over Temp issues as well on my 2001 300x. DDT said "OVER TEMP STARB SIDE", I checked everything and it looked good, did an Ohm reading on the sensor and it checked good based on ambient temperature at time of check. I swapped the sensors between port & starb and the fault went with the swap, it moved to the port side. Replaced that sensor, problem fixed.............Good Luck.
    https://youtu.be/IGkyssK27rU
    **Bullet Proof Foot Control >>>>>$295 + Trip
    **Smooth and fastest throttle response
    **2 LB's Lighter that any cast Hot Foot types
    **All "BILLET" construction, compare, you'll see this is the "BEST IN CLASS FOOT CONTROL"......contact me.
    Gary
    Life Time Member Of The
    Haul'n Ass, Burn'n Gas &
    Honorary Blown Motor Club
    Growing old is inevitable, growing up is optional.......
    Apr 2008
    Malta
    hello again, just wanted to let you know that the problem was solved by replacing the block psi sensor. Without a min of 5 psi block pressure the guardian limits power and sounds a continuous beep. This has solved my issue.
    thanks to all!
    Jul 2007
    Hamilton Ohio
    Thanks for sharing that info, that's good to know for future reference. Glad you got it fixed.
    Gary
