Results 1 to 8 of 8
    longisland ny lindenhurst
    Exclamation hydrostream vulture?
    just picked up a hydrostream vulture,gotta put a new core in it.im thinking on setting it up light and throw my bridgeport on it or beefing it up and throw a stock 200merc on it.Any1 know how those boats run and how would a bridgeport push it?i really dont want to set it up light with the bridgeport and the boat doesnt pop and turns out to be a slug.any help?
    ed
    16ft superboat
    14ft vixan
    15ft viper
    24ft sleekcraft
    21ft sleekcraft modvp
    18ft action hst drag
    18ft accelerator drag
    21ft redline
    18ft vking yt 300 yamaha!
    Long Island N.Y.
    Years ago I had a vulture with a bridgeport, ran 88mph. My hull was light and if I rember correctly I had 8" setback. Boat ran real good and the boat hanged with the bow high.
    Aug 2003
    Warwick,MD
    I had a 85Vegas with the Vulture bottom, with a Bridgeport and light it will run mid eighties all day,mine ran 80 plus with a fishin mota,just gotta learn to fly it.ain't like drivin a tunnel thats for sure.
    Oct 2005
    what bottom vee or the xt bottom
    Aug 2003
    Warwick,MD
    My first one the silver one in the picture was a vee,my second Stream was an XT.I think the vee was a little faster with the same power,
ID:	234657   Click image for larger version.
ID:	234658   Click image for larger version.
    You didn't mention what year. but none the less. You might be looking at a transom also. If so go with Coosa board. My Vulture would run 92 with a hopped up 2.5 and with a modded 2.4 mid to high 80's. Vultures love alot of set back 10" or more. I set mine up with 12". The back to backs need to come out to achieve the real high speeds. Their caracteristic is they come out the hols a little slow but when set up properly they hang really well. Keep in mind the Vulture is not a race boat like the Vking. But is a pleasure to run and drive, and is stable at high speeds.
    Check the pocket behind the pad and make sure there are two aluminum angles on each side. They were installed at the factory. They actually allow the hull to break loose from the vaccum. While you are at it go ahead a blue print ther bottom. They definately benefit from that.
    You'll definately need some seat time to learn how to drive it once you start getting over the 70 hump. IMO invest in a sea star pro steering also.
    Good Luck!!!
    Oct 2005
    had vulture xt great boat roomy cockpit runs nice over chop stabil and turns well agree with setback front seats far forward so when you run two in front takes more to air out runs great with people in rear seats yes setback stock 200 get you in 80s fast stabil and reliable
    ILL
    Yea my 1st boat had to recore the hole boat too. Put a 2.4 BP on her when done cle with a cone chopper 2 prop nose high and tons of set back 10-12" watch the transom with all the set back up need tie bars. Ran mid 80s all day.
    Skydog
    06 Daytona 27'
    600 Cubic
    Whipple 8.3
