Results 1 to 13 of 13
    Apr 2002
    NC
    Piston clearance
    What clearance would you recomend for a steel sleeve 260 motor running mahle pistons? Thanks Tony
    May 2001
    Lake Keowee, South Carolina
    I don't know for a 260 but for a 200 2.5 with steel cyl. bores, the service manual gives .007 for a new block and piston.
    May 2001
    On my motors i ran .002 to .003 over
    So bore size is 3.502 to 3.503 for a steel bore motor. And i guess i tend to stay to the 3.503 mostly. Others jump in on this. Dave
    May 2001
    For a factory steel sleeve motor, bore size is 3.501, piston is 3.494 +or- .001
    Extreme Southeast Georgia
    Some Specs
    From the 2.5 Hi-Performance Service Manual..............................................
    Wayne
    Another
    More Specs.................
    Wayne
    Just curious
    What ring are ya gonna run on that steel bore with that Mahle piston Tony ? The gold rings even with a diamond slick hone have not lived long for us. If the keystone angle cut is the same and the ring is 1 1/2 mm on your suspect Mahle you can use the Pro marine ring for a steel bore BUT the end gap slot has to be cut to accept the locater pin in the middle of the ring lan ! I use John Marles( US1 ) to cut my rings if I have to convert a side pinned to a top pinned ( Or Mahle type positioned pinned piston ). Just trying to save ya some grief that we have found to be in the future with anything other than the set up I just sited !
    Good luck !
    Jay @ JSRE
    May 2001
    Los Angeles Ca
    I use .007 on any Mercury 2.5 piston in a steel bore and .0085 on a Wiseco. This is for motors running no popet and no thermostats.
    Apr 2002
    NC
    Jay, I have been useing the gold rings. They have done ok, but do need alot of breakin time. I didnt post that to start with because I didnt think there was anything else to use..lol.
    John, I would take it that .007 would be 3.501. Going with a 3.494 piston size.
    On a motor like this would you change anything about the cooling. as in the water diverters around the cylinders. changing the size of the water restricters in the heads..ect.. Thanks. Tony
    May 2001
    Los Angeles Ca
    tony nc
    I measure each piston before setting the final bore size but if your piston is 3.494 then 3.351 will do fine. As long as you are running 1/8 stainless fender washers in the heads the cooling will be fine. Was the water pressure 15 lbs. minimum at WOT before.
    Apr 2002
    NC
    The exhaust is dry, it takes some rpms to get up to 15, but it does at wot. The 1/8th fender washers are same as factory right?
  12. #12
    May 2001
    Los Angeles Ca
    No, they are no stock. Just make sure they are 1/8 washers. A 1/8 washer has a 3/16 hole in it. Thats all I would do.
  13. #13
    Apr 2002
    NC
    Thanks for the info! Tony
