Page 3 of 7 FirstFirst 1 2 3 4 5 6 7 LastLast
Results 31 to 45 of 104
  1. #31
    May 2001
    Hickory NC
    Tom is a great guy, I buy from him often. As with the V4 compression on an * should not be compared with a 6 as the 8 has two sets of runners like a 4. While the cut late model heads are an option they dont make the power of a 2.7 head.
  2. #32
    Jun 2010
    Drasco, AR
    My 2.7 heads should arrive on Monday, but I won't have time to test before going to work on my ship. (Btw- the engine on my ship is also a 6 cylinder 2-stroke, but the stroke lenght is over 6 feet and it's turning 94rpm at full speed @ 14knots) I'm planning to first install them and leaving the relief holes unplugged and see what the comp will be. I will then decide if I will plug those holes or not.
    Hal
    "Ton o' metalflake" 1982 Concord Mach II with 1997 Johnson 225 Venom
  3. #33
    Jun 2002
    Winter Haven Fl.
    I would love to see if any top-end increase is there, I know bottom and mid will get much better, Matt
  4. #34
    Oct 2010
    Greenwood Lake, NY
    Maybe it will let you run a little more prop because it builds torque?
    I was going so slow I almost crashed. - JamesGang
    1978 24 Superboat - 250 EFI
  5. #35
    7 Post(s)
    Quote Originally Posted by oldschoolltv View Post
    I sold a set to a guy who claimed 3 MPH's.
    Checkmate 16' 140 Johnson
    Laser 480 (?) 21' w/GT 200
    24' Sonic w/twin 250 Johnsons
  6. #36
    Jun 2002
    Winter Haven Fl.
    I have a new 32p prop now and I just need to give it a try sometime, it is an 88 block do I need to change any cooling lines etc..???? or is it only on the closed deck blocks?
  7. #37
    7 Post(s)
    Should be good to go other than jetting.
  8. #38
    Jun 2010
    Drasco, AR
    I get kinda envious when you are talking about 32" props... I'm thinking I have to get myself a lightweight hull soon. The Concord is great for family fun on the lake, but it's just too heavy for those high speed runs. My goal is to get it up to 70mph.
    Hal
  9. #39
    Oct 2010
    Greenwood Lake, NY
    I feel your pain norsk, I'd be pretty good with somewhere near 70 with my current motor.
    John
  10. #40
    Mar 2009
    Port Saint Lucie
    Well then I feel pretty good, I've hit 70 on the mark. No set up or prop yet. Still learning to keep it under control. Hope to swap the lowers soon.
  11. #41
    Jun 2010
    Drasco, AR
    Right now I can only get it up to 61, but none of my props fits too well. I have been fighting all kins of fuel problems since i got the motor and had to figure that out first. Now that's solved and I can start setting up for some more speed. First I will get those 2.7 heads on, get it jetted properly and then I think I will need a 8 - 12" jack plate and a good prop.
    If I want to scare myself, I can always slack the steering cables a turn. Then I get crazy chine walk at 55;-)
    Hal
  12. #42
    Quote Originally Posted by Gorilla0178 View Post
    that boat should run up around 90. my vking ran 87.8 with a bone stock 95 200hp and a pos prop. Definitely had 90 in it.
  13. #43
    May 2011
    NEW ZEALAND
    hi a omc race tech did an report on using the 27 heads on a early 3 litre cut the heads 50'' in a hot boat mag some years ago we did the mod on a 500 pound boat 130 com and the motor pulled a 14 x 30 cleaver to 6800 cheers 1850 bullet
  14. #44
    Mar 2009
    Port Saint Lucie
    90 , I hope it'll go 90. I hope I can drive it to 90. That would be awesome!!!!!!
  15. #45
    I watched Bobby sr run his 16 with a stock 225 to 90 it was about the second pass he made with the new setup as they just put the motor on that week
    Actions are awesome...
