Results 1 to 7 of 7
    Sep 2009
    baltimore
    78 235 trim and tilt work on 88 vro 110?
    The 235 on the back of my baja 180ss broke a ring and scored the cylinder wall beyond
    repair.I have an 88 110 that is missing the trim and tilt.I was wondering if I could swap
    the trim and tilt off the 235.Thanks, Jason
    Jul 2005
    Lake County, IL
    It should, both the manifold and the stern bracket numbers are superceding...
    Sep 2009
    baltimore
    Thanks for the fast reply.I will be swapping motors out this weekend and will post back after completion.
    Sep 2009
    baltimore
    Got them swapped out this weekend.Everything was the same and fit well.thanks again
    Oct 2003
    LAGRANGE, IL
    You will have to do some electrical adapting as well. The 78 motor is a 3-wire motor and uses a remote control box which mounts under the boat's rear splashwell. The 88 trim electrical is setup for a 2 wire motor with two trim relays in a box that mounts on the engine.
    Sep 2009
    baltimore
    Oh, forgot to mention.Had to swap trim motors out.Other than that all went well.
    Oct 2003
    LAGRANGE, IL
    You are right on top of the situation!
