Results 1 to 8 of 8
    May 2008
    wisconsin
    87 omc 75 (56ci)
    i have a lost foam case 56 ci powerhead on a 15" mid and was wondering what i can do to make it go? can you cut the tuner at all? i was told to cut the head 25cc for pump gas 21cc for race gas, that sound right? also timing, anyone know where the sweet spot it? im going to best 1000ft run. thanks
    Nov 2002
    peterborough
    Nice engine, what,s it running on for a boat thanks ?
    free spirit / ONTARIO, CANADA.
    May 2008
    wisconsin
    Its on a hydrostream hustler v pad with a manual jack plate.
    Nov 2002
    peterborough
    With that you should be turning good rpm,s ,raising comp. might allow more. Are you prepared to ramp up timing, jetting, and rpm, for a little gain and sacrifice reliability? If this is the nitro gear case with a worked prop. I can understand if this is for competition use thanks.
    May 2008
    wisconsin
    Yes this is more for competition use so I'm not super worried about reliabilty. It is a smaller gearcase but I don't think a nitro one. What should I run for timing? And as far as the cc's on the head cutting, did that sound right? Thanks
    Nov 2002
    peterborough
    My questions have been to help arrive at the answers thanks. Your full throttle rpm,s as of now, also your prop dia. and pitch will help others input their knowledge or experience. Myself I am not sure of a recommended answer[s] thanks.
    May 2008
    wisconsin
    I'm running 6000-6100rpm. I'm spinning a 11 1/4"x 23 over the hub chooper. I have boysean reeds, no air box.
    8 Post(s)
    port it to the sst 60 specs and use the megaphone to suit
    apba class specs here www.opcrace.com
    If its a 56'er its 70 hp at the propshaft there never was a 75hp 56ci
