Results 1 to 15 of 23
03-08-2011, 08:31 PM #1
Looking for some history on this 88 V-King YT, and set up suggestions
This is my first post to the boards and my first performance boat. I picked this up late November and have not had it in the water but a couple of times before winter set in and the lakes froze around here. It is a 1988 V-King YT with an 89 Merc 2.4 200 XRI. Current set up is manual 6 inch jack plate, prop set about even with the pad, running a small ear 26 pitch chopper, LWP. Boat runs in the upper 60's but is fairly unstable, turns about 6k on the tach. I am thinking this boat should likely be in the low 80's, but at least in the upper 70's. I bought it on kind of a spur of the moment as it was fairly cheap and close where I live. Does anybody know any history on this boat. I purchased it from a guy in the Saginaw Michigan area and he advised he bought it from a guy in the Fenton Michigan area and it originally had a Mariner 175 on it that blew the lower unit. The boat never seemed to really get the bow up high and aired out with the current set up the couple of times I drove it. I am looking for set up suggestions and if anybody knows a more detailed histoy of the boat that would be great too. I know it has been on these boards previously, I just can not seem to find any of the posts from the previous owners. Thanks for any help and suggestions.
03-08-2011, 10:56 PM #25000 RPM
- Nov 2005
- NE Alabama - Weiss Lake
- 702
- 7
V-Kings are a handful to drive at speed. They are rated for 175 HP but everyone around here drops at least 200 on them. Yours seems like a pretty standard setup. V-Kings take ALOT of seat time to be able to perform at high speeds. Don't give it too much positive trim.
TJ309
Older 17 foot Laser / 2.5L Merc 245 Racer
1993 Speedster 13 / 2019 Merc 60 play boat
2020 Lowe 24' Pontoon boat / 250hp Merc. 51mph!
72 Hydrodyne bubbledeck undergoing keel up restoration
2 Jetski's
03-09-2011, 10:52 AM #35000 RPM
- Aug 2010
- Jacksonville, FL
- 144
Very nice looking boat.
It sounds like you may be down on power a bit. Have you checked the compression?
1986 Baker 18 Mod VP, Yamaha 175
2001 Crest Pontoon, 150 Opti
1968 Sears 14' aluminum, Merc 110
03-09-2011, 10:59 AM #45000 RPM
- Dec 2007
- Chackbay,La
- 408
My dad has one just like this with a 260 cut 2.5. It handle like a DREAM... at 95 u can drive it with one hand. NO problem. I think it all about them training wheel.... (tunnel) Great Boat...
03-09-2011, 11:20 AM #5Screaming And Flying!
- Mar 2003
- Belvidere IL, FARM
- 7,737
- 102
- 115
- 1556
- 514
Looks really nice. Keep an eye on your core and transom.
God, Country, and Fast Boats
03-09-2011, 11:32 AM #6
Make sure the bottom is solid. The bottom may be flexing and causing a hook which is keeping it from flying. I would check that before running it again. If it delaminates at speed it is not pretty.
Ralph Musser
27' Fountain Fever W/ 525SC
22' Rapid Craft W/ Evinrude 300 V8 January 2009 BOAT OF THE MONTH SOLD
24' Triton 240 Gold W/ Mercury 60
14' Royalcraft W/ Evinrude 75 father/daughter project
03-09-2011, 07:14 PM #7
I have looked the bottom over as well as I can without cutting into it. The floor is original, so I know the core must be as well. I have looked over both sides of the center pad and can find no stress cracks on it, and it appears to be solid everywhere with no hallow sounding spots when you knock on it. The floor on the inside of the boat is nice and solid everywhere as well with no soft spots. I do not believe the core to be an issue with the boat at this time, but I do realize virtually all of them have had issues or have issues. The prop condition it less than perfect, but not THAT bad (it has been repaired once in the past it appears). I have also tried a very clean 26 pitch big ear chopper and the speeds were virtually identical to the small ear that came on the boat, and I tried a 26 pitch clever and once again the speed was about the same, maybe even a little slower with it. I have compression checked the motor and cold it had 115 psi in all the cylinders (plus or minus about 2 lbs) so I do not think the motor is the issue. Should the prop be much stiffer? I would think with a 26 the motor should easily over rev but it runs about 6k with all the props on it, if I get the plate up any higher I believe it starts slipping and not hooking as well (but it will rev higher, but goes slower). I hear these boats run best with about 10-12 inches of set back to get them to fly without a lot of trim, but I also see several other similar YT hulls on her claiming in the 80's (and more sometimes) with a 6 inch plate and a 200 similar to what I have. This one never seems to fly reguardless of the amount of trim (although it will throw an impressive rooster tail, but I would have bought a jet if I wanted that, LOL!), it seems like the bow never flys that high to really get air under the hull.
03-09-2011, 07:41 PM #8
There's many things that you can do to increase the speed and handling, pending the motor is running correct. For starters, get the propshaft up higher, atleast an inch over, and things will calm down a bit. I fought mine at the beginning also, but really, all of these hulls require the basics of tight steering, solid mounts, etc.. one exception i found with mine, was the higher i ran the prop, the better it handled and increased speed. also, the increase in setback from 5.5in to over 10 helped on mine.. watch your water pressure and bottom delamination.
2004 Checkmate Pulsare Bowrider
2008 Mercury 300XS
91.7 - MPH
88' Hydrostream Viper
86' Carbed Bridgeport
102 - MPH
03-09-2011, 07:50 PM #9
What kind of speed should I expect out of this. I would assume 70 is well on the low side. I would think in the low to mid 80's should be reasonable, or is this incorrect? I am going to raise the motor to about 2 inches above pad and see if it will still hook up. I am thinking about also switching to a 10 inch jack plate if my steering cables have enough length on them still. Can you tell me if going to the 10 inch plate has any negative performance issues (I have heard that it makes getting on plane more difficult, is this true)?
03-09-2011, 08:13 PM #10
if your referring to the propshaft height, you will not have water pressure that high. Set it at an inch above, and go up in small increments while watching pressure. I was able to go around 1 3/4 over the pad with 10.5in of setback. Mine was a bowrider, your vking prob doesn't need that much setback. The negatives to that much setback would be getting on plane, porposing, water coming over back when coming off plane.
2008 Mercury 300XS
91.7 - MPH
102 - MPH
03-09-2011, 08:15 PM #11
yes, a strong 200 should run over 80 on that hull.
2008 Mercury 300XS
91.7 - MPH
102 - MPH
03-09-2011, 08:26 PM #12
Thanks for the info. I definitely do not want it to be more difficult to get on plane, and the boat already slow speed porposes more than I thought it would, so more set back does not sound like it would be the direction I want to go. Is it pretty normal for the chopper props to cavitate on take off. I may need to just play around with the current set up some before I make a decision on where to go. I would think a 200 should easily spin a 26 pitch prop to well into over rev territory, but this one does not.
03-10-2011, 04:33 PM #13
If the motor is healthy and you are hitting a brick wall at about 70 then your hull is flexing at speed. If it's the original core then it's a safe bet that it needs one. Besides being dangerous, you'll never reach speeds that boat could be capible of.
03-10-2011, 07:00 PM #14
Tell ya what, If ya can't figure it out, come to a Michigan hot boat meet. Tons of knowlegible guys with similar rides that can help ya out! You will be impressed!
03-10-2011, 07:07 PM #15
Get that motor all the way up and try it. I've got the 200 on my Varmint (Vector hull) as high as it will go with a CLE lower and that is where it seems happiest for performance. Yours looks to be in the middle of the jackplate.
I run a 27p SRX on mine and it will over-rev. I can get 80's. Previous owner got low 90's. Scares me to death at speed but it's fun to know it can do it.
Also, just for grins, check your compression and timing.'72 Glastron GT-150 Johnson Stinger 65
'83 Hydrostream Varmint 2.4 225 Mercury
'05 Hydrostream Voyager 250xs optimax
