Results 1 to 3 of 3
Thread: 2.4 L carb question
02-18-2011, 11:54 PM #15000 RPM
- Feb 2011
- Michigan
- 131
2.4 L carb question
I have a few sets of carbs,
1 set (3)has hand stamped in them wh 31 (all the same on each carb)
1 set has hand stamp 39-1 then 39.2, then 39.3 (on each carb progressively)
what is the difference between these sets of carbs
02-19-2011, 03:27 AM #2
on the inline 6 motors the top carb had a 1 , the middle carb had a 2 , and the bottom was stamped with a 3
Probably the same thing.
Not sure what the other set is about that has the same numbers on them?L6fan57-88
02-19-2011, 09:39 AM #3Screaming And Flying!
- Springfield,La.
- 6,579
- 17
- 2 Thread(s)
Tha 31's are from a 2fo 200.....They will all have 1, 2 and 3 on them.....Each carb iz a lil differnt bekause ov tha choke inrichment...Tha #1(Top) haz a fitting on tha bottom ov tha bowl for fuel delivery to tha inrichment solonoid, and tha carb body haz no fitting on top for fuel inrichment delivery....#2 (second carb) haz a "T" fitting on tha top ov tha carb body for fuel inrichment delivery...#3(bottom carb haz a fitting on top ov tha body that faces tha port side for fuel inrichment delivery.....Also on most 2fo'z, tha jetting for cyls 2 and 5 are differnt..Other than toze few differnces, they iz tha same carbs!!
