Results 16 to 30 of 42
    Aug 2010
    N.Florida
    Ok, with it idling on the water hose the timing is at 3* I popped the timing linkage off the throttle arm and advanced it all the way to the full throttle stop was 27* so total timing is 27* at idle speed.
  2. #17
    NE Louisiana
    You can't do it that way.
    The timing will grow as it increases RPMs. You have to set it at 4500 to 5000 rpms with a test wheel or strapped down really well to the trailer.
    Move the throttle arm, the timerbase should move first. Then the throttle cam will contact the roller on the carb linkage (as said, sometimes with age these will fall off).
    A link and sync proceedure is in a manual. If you don't have one, get one, preferably OMC (check eBay).
  3. #18
    Jan 2011
    copiague
    Link and synch is out, Perform a link and synch procedure, this will definately wake it up, also if this does not do the trick, you are looking at blow-by problems and possibly bad reeds
  4. #19
    Oct 2003
    LAGRANGE, IL
    The specific idle timing degrees is relatively unimportant. All engines will vary, depending on setup and how deep the engine is in the water-when floating on a specific boat. The idle needs to be set to a specific rpm (650-750) when in gear, floating at normal level in the lake. If the idle rpm it is too low, you can have issues with the throttle up.
  5. #20
    Aug 2010
    N.Florida
    Quote Originally Posted by Forkin' Crazy View Post
    I've got a clymer manual and did the carb. Link adjustment as instructed.
  6. #21
    Aug 2010
    N.Florida
    Quote Originally Posted by rukkus View Post
    I looked at the reeds when I had the carbs off for cleaning everything looked good.
  7. #22
    Aug 2010
    N.Florida
    Just did a comp. Test #1-87psi, #3-90psi, #5-85psi, #2-82psi, #4-80psi, #6-82psi, don't have a leakdown tester so I can't check that yet.
  8. #23
    Ft. Lauderdale, Fl
    Floats should be level with the gasket surface whn the carb is held up-side down with no pressure on the float
  9. #24
    Oct 2003
    LAGRANGE, IL
    Checking the max timing on this engine should be done at 5000 rpm. Not an easy task. You can check the max timing by disconnecting the link arm (spark advance rod) between the timer base and the throttle advance lever. When idling, you can momentarily advance the timer base arm to the max stop and check the timing on both #1 and #2 cyls. Keep in mind that the ignition system on this engine will read max timing about 4 degrees lower at idle that it will actually be when you are running at 5000 rpm.
  10. #25
    Oct 2010
    Harrisburg,Pa
    If you have done all the above and you are sure carbs and linkage is right then you have a air leak. Crossflows leak between the intake and crankcase between cylinders. (not to the outside) So remove intake and reed cages and surface intake on a piece of thick glass with 120 grit sandpaper and you will see if it is warped or not. Then check the crankcase also. They all warp here. Because of the thin area between cyls this has to be right.
  11. #26
    Aug 2010
    N.Florida
    Quote Originally Posted by perfmarine1 View Post
    I've been leaning towards a vacume leak but that makes since ill check that next.
  12. #27
    Aug 2010
    N.Florida
    So what should I set my max timing at?
  13. #28
    NE Louisiana
    Did you check the recirculation hoses and valves?
    Quote Originally Posted by wanagofass View Post
  14. #29
    Aug 2010
    N.Florida
    Couldn't find a vacuum leak but im not sure how to check the valves
  15. #30
    NE Louisiana
    The are one way valves. Easy to check. Air will pass one way and not the other.
