Results 1 to 13 of 13
Thread: yamaha pro-v 150 carb hop-up's?
01-10-2011, 07:04 PM #15000 RPM
- Dec 2002
- jonesville, La
- 716
- 11
- 83
what can be done to increase the hp on the yamaha pro-v 150 I'm normally a merc man but the old 2L gave up the ghost, can you do it like the merc's and open up the chest and advance the timing and comp anyone have any suggestions
thanks Pete
01-10-2011, 07:48 PM #2
01-10-2011, 09:14 PM #3
Call Noah!!! Great guy to deal with. I have always heard that adding the 200 carbs will wake them up. I have a Pro-v 150 here now I just rebuilt the carbs and they have a very small venturi.
James Perry
01-10-2011, 10:30 PM #4
you can use reeds and carbs fom a 200 or a 220 special. the heads on a 220 or a 225 will be better. the 220 tuner is also good. if you can get a horizontal front half, carbs and intake from a 225 with the 220 tuner and heads and use the 150 ignition with the rev limiter removed you will have a solid motor that will rev to 7000 rpm. i run that combo on my allison and it sees 7500 regularly...............benji
hold on and hope for the best
01-10-2011, 10:35 PM #56000 RPM
- Jackson,Tenn.
- 1,691
What year model is it?
Ray Neudecker Over The Hill Gang Outboard Racing
01-11-2011, 11:31 AM #6Markus' Performance Boating Links:
01-11-2011, 05:36 PM #75000 RPM
- Aug 2010
- Jacksonville, FL
- 144
01-11-2011, 07:40 PM #8
i have been running it like this for several years now.
bakerfreak, the pics are too small and i cant tell. if you are wanting to build one the best advice i can give is to talk with ray. he is a wealth of knowlege and one of the few people i have met that will actually talk you out of spending money on needless parts............benjihold on and hope for the best
01-11-2011, 10:07 PM #95000 RPM
- Aug 2010
- Jacksonville, FL
- 144
Yeah, sorry. Ray, can you chime in? I'm curious as to what front half flows better. The Excel or Pro-V type has really defined intake runners that look like they would flow pretty well. The other type has more of a flat face where the reed block is. Does one have more reeds than the other or a tighter crankcase? My motor is the flat face 175, but I can get an Excel powerhead pretty cheap.
01-12-2011, 10:45 AM #106000 RPM
- Jackson,Tenn.
- 1,691
The Excell will basically out do the vertical motor for many reasons including the porting, carbs and horizantal front half and intake. If used on your old midsection you need to also change to the old V-6 special or Excell tuner.
01-12-2011, 11:13 AM #115000 RPM
- Aug 2010
- Jacksonville, FL
- 144
Thanks Ray,
Sounds like the Excel is the way to go. The motor I'm looking at is a 25", but I guessing that the tuner would be the same.
01-14-2011, 03:07 AM #125000 RPM
- Dec 2002
- jonesville, La
- 716
- 11
- 83
motor is maybe early 90's at best? So just basic hot rodding on the motor. motor runs great just needs some more hp for the old vector
01-14-2011, 09:55 AM #136000 RPM
- Jackson,Tenn.
- 1,691
Check for the model number. Should be on the clamp bracket. They made many versions over the years and different mods to produce the best results.
