Results 1 to 13 of 13
Thread: 07 300xs
01-04-2011, 07:15 AM #1
07 300xs
just bought a 07 300xs that has never been on a boat,just wondering are thier any changes made on the newer models than the one I have,if so what are they,and why
Im putting this motor on a 25ft cc fountain,also need some info on what kind of prop to start with
thanks Gary
01-04-2011, 10:22 AM #2
I also have a 23/25 Fountain CC. Mine has a 225 Opti and we have run every prop imaginable. The best we found to be the Hydromotive Quad IV-X but you might want to try a Bravo. I cant spin a 22 Bravo but you sure will be able to or bigger. Maybe the new Bravo XS. The hull tends to porpoise under 40 mph and the Hydro settled it down a lot over the Rev4 that came on the boat.
Mount the engine all the way up. MIne came with the engine all the way down and we kept moving it up. Its now all the way up and water pressure is great. Speed and porpoising got better as well. This of course is assuming they drilled the transom the same. I can take a measurement of you want.13' Biel tunnel AKA "Flight Risk"
21' Paramount
Mercury 300 Promax
01-04-2011, 09:07 PM #3
01-07-2011, 11:05 AM #4
mr demeanor,if you get a chance ckeck yours from top of transom to center of top bolt,and I will try some of those props if it will ever warm up some
thanks, merctech5591 Iwill check that out when I pick motor up,I was looking at the etec 300 and the 300xs,found best deal on the merc,hope to see 55+ mph with right prop,not going to fish this boat just ride without getting beat to death,big change from my V21 with a 280
thanks guys Gary
01-08-2011, 12:56 PM #5
Not to bust your ballz but that's not correct, there were a few changes / updates made... Several bearings and seals were changed. The coils were all changed and also the ignition harness. I've also heard the processor in the ECU was changed or updated
but I can't confirm that one.....
Gary, what lower unit ratio did your XS come with? Im assuming it is a Torque master?Last edited by Adam McKeon; 01-08-2011 at 01:00 PM.
01-09-2011, 08:01 PM #6
21' Paramount
Mercury 300 Promax
01-10-2011, 10:09 AM #7
56mph is 55+ that will have to do if your cal. are right,the 300xs is to replace a gas gulping 250efi,that Im going to sell this spring,Ive had somthing that would run 95+ for 14yrs so Ive had my fun,just thought it would run a little faster than 56, but if that is all it will do Im good with it,I just wont be burning as much fuel with the 300 vs this 250efi,and thanks for your interest,let me know what those mesurments are
btw its snowing like sh!* here
01-10-2011, 11:22 AM #8
Be sure and post some pictues once you get it rigged, and of course your numbers
22' Activator w/ 250xs Merc Opti, back home again
01-11-2011, 12:12 PM #9
will do,looks like its going to be a while with this snow and ice,wonder if they have turkey houses in FL
01-11-2011, 12:22 PM #107000 RPM
- Apr 2008
- Washington N.C.
- 2,154
wonder if they have turkey houses in FL[/QUOTE]
YES..
01-11-2011, 06:31 PM #11
The measurement from the center of the top engine mount bolt to the top of the transom (mine has an aluminum cap) is exactly 2".
21' Paramount
Mercury 300 Promax
01-12-2011, 12:58 PM #12
thanks mr demeanor I will check mine
DBS,you are a fountain man,what do you think a 25cc will run with a 300xs
01-12-2011, 03:51 PM #13
Give Ken at Propgods a call. He has propped out a few 23/25 Fountains and has the calculator I used. He has some good data and is a good guy to talk to.
www.propgods.com13' Biel tunnel AKA "Flight Risk"
21' Paramount
Mercury 300 Promax
