Results 1 to 3 of 3
Thread: painted strip coverup help
01-03-2011, 01:44 PM #15000 RPM
- Apr 2006
- 129
my boats a 95, magenta and pink was in during the late 80s, id like to cover it up with a silver and red. they pink and magenta is in the gelcoat. can it be painted over or should i have a vinal decal made to cover it? some is in down by the water line. the boat is not stored in the water.
Jeep Cherokee SRT8 550hp
Camaro SS Turbo/1300+ hp
Malibu Flightcraft 200 XRI
01-04-2011, 08:57 PM #2
someone on my boat had hone a shotty job at painting over the gelcoat (bad surface prep) and it was pealing but some 400 grit and a nice clean surface should do you well
Just My Two Cents
Im Sixteen years old, and have an obsesion with performance marine propulsion? Wierd EH?
197? Humber Jewel 40hp Mariner 4cyl SOLD
1980 16ft Sidewinder SS16 - Project Pad Me
197? 15ft Gw Invader Project Hull
Youtube Channel Click-->: MovieMakerPro77
01-14-2011, 09:35 PM #35000 RPM
- Feb 2003
- Chicago
- 756
- 10
use good fine line tape to mask out side your stripe,orbital sand or 320 wet with a block,hand sand the edges.re tape and clean fiberglass with a prep solvent.buy one of those airless co2 sprayers and mix your paint.west marine sells 2 part paint.spray lite coats 3 will do fine.let dry a day or two 1200 wet sand the orange peel and buff.I have painted a bunch of small boat bottoms this way and they look just as good as when I do it in the spray booth.
THE BEST PART OF LIFE IS SPENT ON THE WATER
