Results 31 to 45 of 94
10-04-2011, 10:31 PM #31Member
- Sep 2011
- bay area
- 56
That's sad Merc should step up to plate and fix your motor.
Based on the above, I would not bolt on anther compressor without measuring the runout of the compressor pully and checking the tensioner.
what Hp is the motor and were the fuel rails/injectors service when changing the compressor?
pwr
01-25-2012, 08:57 PM #32Member
- Apr 2005
- Asheville, NC
- 65
Any update to this? I have a failed Tohatsu TLDI compressor that is of similar (only one bearing on one side of crank) that has failed. I'll start another thread on the failure mode with pictures.
03-13-2012, 08:44 PM #33
I think the filter in the air pressure line to the compressor is a good idea,someone on here already posted about this.You may have to change it often,guess depends on how much debris gets in the filter.
03-14-2012, 09:14 AM #34
06-20-2013, 02:32 AM #355000 RPM
- South Africa
- 576
- 31
I am still waiting to see one of the new design compressors and yet we are still having failures
07-10-2013, 06:03 AM #36Screaming And Flying!
- Jun 2007
- Singapore/Melbourne/Italy
- 9,109
- 1010
- 356
- 4327
- 1976
- 8 Post(s)
how about a paxton, you know where to put the spare air?
how reliable is the compressor on a truck?
class action should get it fixed
07-25-2013, 07:36 PM #37Junior Member
- Aug 2007
- 17
Subscribed. A friend of mine is getting a 2014 version of a 300XS. He is being told that that it puts out an additional 17 hp due to the compressor upgrade. I think someone is feeding him a line of crap, but I have yet to find anything stating otherwise. If anyone has any real info, please post it.
07-25-2013, 08:24 PM #38
If it makes 17hp with the new pump then I'm changing mine(2007 300xs)!
90 21Skater w/300xs - sold
98 STV Euroski w/280 - sold
07-25-2013, 09:04 PM #39
I don't believe it.... But I wouldn't know...
Cawley
07-31-2013, 06:19 AM #40
07-31-2013, 06:49 AM #41
+1 , If it were not for cost savings no body would use castings. Many times we have to shift all of our machining one way or another in an attempt to get the casting to "Clean up". Its always an issue , core shift, worn tooling low paid low skilled employees.
L.T.
07-31-2013, 12:48 PM #42Registered User
- Mar 2005
- Ontario CANADA
- 555
- 100
- 1314
- 109
07-31-2013, 04:42 PM #43Screaming And Flying!
- Jun 2007
- 9,109
- 1010
- 356
- 4327
- 1976
- 8 Post(s)
08-01-2013, 07:33 AM #44
No ,that was a slick surface.It has been hammered off by the rod bearing.I have seen it many times on outboard cranks.We have seen a great improvment on the new style opti compressor.The new one is now painted black . hf...
08-01-2013, 08:01 AM #45
Gary if you don't take this one, I guess I will....
HF,
Based on your statement two engineers (one with over 30 years and the other with over 20 years of manufacturing experience) from "Americas Biggest Industrial Company" (Fortune Magazine) which is ranked #8 on the Fortune 500 don't know what a bad casting looks like.
There is absolutely no way the void shown above in the machined surface was caused by a mechanical failure.
While I'm sure there are many failures in the field where the bearing and/or rod chewed up the journal, this particular situation is a bad casting which would be the root cause of a bearing failure down the road.
Respectfully,
Ken WolkensLast edited by Stitch King; 08-01-2013 at 08:04 AM.
