Results 1 to 15 of 17
    Aug 2006
    Kingsland GA.
    Sporty leaking oil. Advice
    It dont leak alot but there always seems to be some oil leaking out around the prop shaft. I have ran it and it never gets water in the gearcase but, tends to leak about 5-10 drops out after I park it. I always let a ounce or 2 run out of it to make sure it aint over full when changing the gearcase oil. I am thinking the sealing area on the shaft is corroded and thats why its leaking. Crossing my fingers that the seals are just bad. I had it rebuilt 2 years ago and the drive shaft had to be replaced because of the corroded sealing area. I am thinking about replacing the seals and seein if that works. I have replaced these in the past on a stanard fishing motor and they are a real pain in the ass to get out without scarring up the prop shaft sealing area. My real question is. What do yall use to remove the 2 prop shaft seals?
    Thanks
    Mar 2007
    Tampa, Florida
    Don't risk the prop-shaft, pull the carrier and knock out the seals.
    Doug (Enticer1)
    1998 Avon RIB with 9.9 Yammer
    Looking 4 another Mirage
    Mar 2003
    Belvidere IL, FARM
    Quote Originally Posted by Enticer1 View Post
    What he said !
    Chris
    God, Country, and Fast Boats
    Jul 2007
    Hamilton Ohio
    Just an FYI...........Don't know if I'm the lucky guy or not, but I've never had to pull anything to get them out. A long sheet metal screw or dry wall screw and a good yank, out they came. On the reinstall I clean out the bore w/brake cleaner on a Q-Tip and use Loctite 242 (BLUE) applied with a Q-Tip in the bore prior to seal install. Never had any issues of them coming out.
    Gary
    Growing old is inevitable, growing up is optional.......
    Pekin, IL
    That's a pretty good idea Gary. I might suggest Loctite 609 (green) however as it is a retaining compound as opposed to a threadlocker.
    Rock
    Team Junk
    Jul 2007
    Hamilton Ohio
    Quote Originally Posted by rock View Post
    Rock
    Rock,
    The 642 Threadlocker is just enough to hold the seal from getting loose, I still have a good press fit and I only use it for a little added insurance and removal can be done without any damage to surrounding surfaces.........If I had a slip or looser fit I'd agree with you on using 609.
    Gary
    Sep 2002
    Dublin, Ireland
    If the shaft is pitted badly and thats causing your seal issues. Get a SS collar made up and sweat it over the propshaft. Put new seals in and you shouldnt have the issue again.
    Power Marine 650 Offshore Race, Yamaha 130 Pro-V
    Pekin, IL
    Quote Originally Posted by Liberator*21 View Post
    I am certainly not a Loctite expert. I just read the bottles. Is the 609 a lot tougher than the 642?
    Rock
    Team Junk
    Jul 2007
    Hamilton Ohio
    It sure is.........
    Gary
    JAX. FLORIDA
    Rock
    The green Locktite is a stud and bearing mount anerobic compound and is tough as nails. Most of the bearings and gears mounted with the Green need 700* of heat to remove them.
    "Confidence" is that wonderful feeling you had right before you fully understood your true situation.- Unknown
    I don’t know what effect these men will have upon the enemy, but, by God, they terrify me.- Duke of Wellington
    “I am not afraid of an Army of lions lead by a sheep; I am afraid of sheep lead by a lion.” – Alexander the Great
    Whoever said the pen is mightier than the sword obviously never encountered automatic weapons.-Douglas MacArthur
    Allison GSE 300XS
    Pekin, IL
    Thanks guys. Great info to have.
    Rock
    Team Junk
  12. #12
    Aug 2006
    Kingsland GA.
    Does the small shaft sporty use the same seals as a standard small shaft v6 gearcase?
    Thanks.
  13. #13
    Feb 2006
    north fla.i think
    Quote Originally Posted by K-Dawg View Post
    Thanks.
    no thet do not !!
  14. #14
    Quote Originally Posted by Alan Power View Post
    No need to make, already sold...great for corroded trailer axles too. Click the link...its the ticket, but doing one a prop shaft, with out a lip the shaft, might be prob. Just a thought..
    http://www.skf.com/portal/skf/home/p...=4_5_3&lang=en
  15. #15
    shreveport,la
    Thanks.
    The Sportmaster has a different propshaft than the standard 200 case
    Erik Kiser
