Page 2 of 2 FirstFirst 1 2
Results 16 to 24 of 24
    Jun 2013
    san luis obispo, ca
    With the strainer out flushing water through the flush attachment forces water out the hole where the strainer goes and back flushes down the water tube and the pee hole.
    [SIGPIC]
  2. #17
    May 2011
    deep river
    Nice post.
  3. #18
    Feb 2010
    Tarpon Springs, FL
    Quote Originally Posted by slofisher View Post
    I did not say remove the whole fitting! Just cut the screen off the fitting!!! The screen is not a check valve lol.
  4. #19
    Jun 2013
    san luis obispo, ca
    Hey Rude Runner. I was merely describing the water flow when you flush using the adapter. I had pulled out the strainer looking for a peice of gasket that had broken off the water pump. I pulled the screen out which had some debris but when I ran the hose through the adaptor with the screen out a lot of debris shot out along with the broken off piece of gasket. I think that screen should stay in to prevent crap from moving further up the stream.
    [SIGPIC]
  5. #20
    May 2001
    great south bay
    Great info, Does mercury recommend this procedure or is this just something that comes about from a failure? Is there a diagram out there that shows cooling water flow? Is it in a service manual?
  6. #21
    May 2001
    great south bay
    Mr D. I see in your first post you have a picture of the service manual. Can you post a picture of the cooling water diagram?
  7. #22
    Sep 2010
    Toms River New Jersey
    Great post.. Just did mine was very clogged I have only 90 hrs on my 06 225 optimax.
  8. #23
    Sep 2010
    Ft. Lauderdale, Fl
    a 1/4" drive 8mm swivel socket and long extension makes removing the side pans easier...... also, a ty-wrap tool will tighten the ty-wrap without putting too much stress on the plastic fitting and can be used on all ty-wraps.....
