Results 1 to 7 of 7
    Oct 2009
    cold lake
    Annual maintenance/inspection items for merc racing optimax. ????
    What should I be doing, inspecting, or verifying on the unit annually? I want to take good care and will be maintaining it myself. Don"t want to overlook or neglect anything!!! Use it in freshwater, run it LOTS, it is new and I would like to go over it from the skeg on up. Beyond gear oil, grease job.
    Aug 2005
    Pembroke Pines , Fl
    Quote Originally Posted by xsflight View Post
    red top filter, oil strainer, return oil filter's coming from the air compressor. check plug gaps and make sure you run quicklean. also check thermostats for debris. on little rock stuck in the thermostat and it will drop temps to 85-90 deg and never warm up.
    Oct 2009
    cold lake
    THANKS FOR THE REPLY MERTECH5591. red top filter??? oil strainer-check, return oil filters from the compressor have been eliminated-by mercury, plug gaps and condition-check, QUICKCLEAN????? uncertain of specific product or procedure/interval?? I have added fuel stabilizer. thermostats-check.
    May 2010
    Sarasota, Fl
    What year engine do you have? There should be a red top fuel filter screwed into the top of the VST.
    Oct 2009
    cold lake
    2010 - 2.5 It has a screw on filter on the VST.
    Injector cleanings.
    Oct 2009
    cold lake
    What products would you use? Is this something mercury recommends? fuel additives I presume? Oh i should replace the compressor's air filter in the flywheel cover as well.
