Results 1 to 15 of 16
Thread: early Xflow gearcase ratios
11-14-2010, 12:07 PM #15000 RPM
- Sep 2008
- Mass
- 450
- 16
- 39
I have an OMC 73 135hp gear case and a 73 115hp gear case. do these two lowers have the same gear ratio or different? i checked the gear part numbers and they are all different. logic would indicate if their different the 135 would have the numerically lower gear ratio. is that correct? anyone have a list of gear case ratios by year and HP size for 70's Xflows?
11-14-2010, 07:05 PM #2Team Member
- Lake Coochiching, Ontario
- 7,746
- 271
- 485
- 1569
- 6 Post(s)
The oldest brochure i have is 1978. All V4s were 2:1 that year.
11-14-2010, 08:00 PM #3
I just looked in our 73' service manuals and and they should be the same (2:1)... but the books technically say the 85hp and 135hp are 13:26 and the 115hp is 13:25, I bet its a typo... and should be 13:26 like the rest...
Dan Cario
1994 STV Mod-VP w/225HO Ficht Evinrude
1987 22' Velocity w/225HO Evinrude E-Tec
11-14-2010, 09:33 PM #4
the oiler-style units on the 135 were 1.92:1 (13:25)...
11-15-2010, 06:40 AM #55000 RPM
- Sep 2008
- Mass
- 450
- 16
- 39
whats an oiler style unit? how do you account for the gear sets having different part numbers for the 135 and 115?
11-15-2010, 07:42 AM #6Supporting Vendor
- Sep 2006
- Key Largo, Fl
- 3,272
- 215
- 30
- 585
An oiler unit is called so because it uses an oil pump run off the forward gear to power the shift mechanism,this unit,1973-1976,was properly called 'powershift',the 85 had a 4 spline driveshaft,the 135 had 20 splines,most likely thats where the gear differences came from,chris
11-15-2010, 11:38 AM #7Member
- Feb 2010
- Minocqua
- 97
When I started at Evinrude way back in '68. And when the 1969's came out, all V-4 crossflows where 2:1 from that point on.
11-15-2010, 07:47 PM #85000 RPM
- Sep 2008
- Mass
- 450
- 16
- 39
well thanks guys. I just went and checked out both cases. the 135 unit does in fact have a 1.92:1 ratio. I marked both shafts and props and spun the props. the 135 unit was consistently less than 2 turns of the drive shaft for 1 turn of the prop checked visually by my marks. the 115 unit was dead on at 2:1
11-15-2010, 09:27 PM #9
From 73-76 the 135s all had 1.92:1 gears. The 77 140 had them too, but used a newer style case with swept skeg. The 1978 140s changed to a non-oil-pump unit and 2:1 gears, and they stayed that way until the end of the crossflow V4 production.
Tiger
11-15-2010, 09:34 PM #105000 RPM
- Sep 2008
- Mass
- 450
- 16
- 39
good to know glad i figured this out. i had been using the 115hp 2:1 unit on my boat previous. the 1.92:1 will give me better prop selection turning a smaller pitch faster is easier than getting a bigger pitch some times with the small gear case.
11-16-2010, 08:53 AM #11Screaming And Flying!
- Jun 2007
- Singapore/Melbourne/Italy
- 9,109
- 1010
- 356
- 4327
- 1976
- 8 Post(s)
11-16-2010, 09:25 PM #12
11-16-2010, 09:29 PM #135000 RPM
- Sep 2008
- Mass
- 450
- 16
- 39
right its not much, but it will decide which gearcase i rebuild and LWP cone over the winter for a project
11-16-2010, 10:01 PM #14
11-17-2010, 02:50 PM #15Member
- Feb 2010
- Minocqua
- 97
MMMMMMMMMM 1.92 ratio on the 135's, well I've been wwwwrong before. But I can't remember is the second or third time??????
