Page 11 of 34 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 LastLast
Results 151 to 165 of 503
  1. #151
    Jan 2007
    Amityville/Lindenhurst
    forget glassing Monday, high temp of like 15
  2. #152
    Callahan, FL
    Boat is looking great, keep all the pictures of the progress coming.
    One more incentive picture for you.
    #12 Miller American SST 140 Tunnel hull
    1970 Glastron Carlson CT-15, Merc 1350
    1977 Hydrostream Ventura II Comp, under construction. Have 1500xs waiting.
  3. #153
    longisland
    Your gearcase is in process. All welded ready for filler work and then some paint. Heres a pic. Bay looks really cold!!!
  4. #154
    Ronnie do you tig weld that? Very nice job.
  5. #155
    longisland
    Yes sir. Tig welded all the way around. Yours will look the same. I'll post you some pics when I get your cone.
  6. #156
    May 2010
    Baldwin ny
    Two things I remember about mine before you glass the floor it had access panels for the fuel tank, it was trimmed around it with stainless.
    small 8" round access holes in front of each seat stanchion so you can through bolt the seats to the floor which I remember became quite important when one of my drunk fat ass friends pulled the bolts half way through the floor while running to manhattan after drinking too much at Aj's in Atlantic beach. In hind site I would have put laminated blocking under the floor to increase the strength.
    What do you plan On using to finish the floor? I always told myself that if I ever redid the floor I was going to use that Armstrong stuff with the dots.
    Keep it up I know the cold sucks
    Bobby
  7. #157
    Oct 2009
    lindenhurst new york
    Quote Originally Posted by berzerko View Post
    Bobby
    the tank is permanantly glassed in and no longer has the access hatch, and im not using the factory seat bases. i am going to be making fiberglass bases and glasseing them down to the floor. those stainless bases are rediculously heavy so i will cut down on some weight and also have a new floor with zero holes for water intrusion. the surface of the deck is going to be getting a layer of 1.5 ounce matt and a layer of 1708 biaxial. i am going to leave the floor raw finish and roll gelcoat on it. i had planned on fairing and painting it but thats going to end up taking me awhile. mikeylarge's deck was done with gelcoat under raw finish and it looks excellent, so ill be doing the same to save me some time. I layed down two layer of very wet matt on top of the stringer wrapping the first layer to help seal the stringer and then the floor was screwed down to the stringers. the floor is not moving anywhere its down good and tight and after its lominated over the top its going to be pretty rigid.
    Ronnie: the case looks like its coming along nicely! cant wait to see it all finished
    21' Shadow--250 3.0l
  8. #158
    Jan 2007
    lindenhurst
    Picture of my floor for example.... no frils, glassed gas tank hatch down and did some quick ginding and rolled 2 coats of gelcoat over the 1708 looks pretty good, amd I dont have to really care about it because its not perfect!
  9. #159
    May 2010
    Baldwin ny
    I found some more pics although most of the ones I found are of girls on the boat which i do not think are appropriate on this thread, unless you want me to
  10. #160
    Jan 2007
    lindenhurst
    Girls are appropriate on any thread!
  11. #161
    Oct 2009
    Quote Originally Posted by mikeylarge View Post
    I agree!!
  12. #162
    May 2010
    Baldwin ny
    ok how do you post the pics so there not in thumb nails
  13. #163
    The suspense is killing me. Come on already
    Use a site like photobucket to post
  14. #164
    Jan 2007
    stop trying to pick them up with your thumbs
  15. #165
    May 2010
    Baldwin ny
    ok here you go this pics are around 20 years old and scaned from print
    this is the reason to have a wind screen
