Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 37
    Sep 2009
    chicago (actually approx. 1 hr SW)
    78 Checkmate Jetmate Restore
    Just started my restore of my 78 Checkmate Jetmate, stripped down and put on blocks ready to start fiberglass/sanding for the new paint job... More to come
    Aug 2009
    Windsor Locks, CT
    cant wait to see more pic of your progress!
    Is a bird in hand worth two in the bush?
    NRA Member
    1979 baja BR180 Merc 175
    1986 Checkmate Starflite awaiting paint
    Sep 2009
    Started filling all of the holes in the dash area, antenna, lights, and other bad spots. Mocked up the engine cover and started glassing it together... More to come
    Attached Thumbnails Attached Thumbnails Photo095.jpg   Photo093.jpg   Photo092.jpg   Photo094.jpg
    Restoration threads are my favorite - please keep the posting your progress.
    Jan 2010
    NC
    Just picked up a 76 checkmate a few weeks ago, Lots of room in that bad boy.
    The one got is red flake. Will get some pics soon.
    Looks like you will have a good as new before long...
    Sep 2009
    Slow progress, I've been working a lot
    Still getting the sides of the engine cover glassed/glass bondo'd
    Sep 2009
    New switch fab.....
    I am going to make it a push button start (no key) and I wanted to change all of the switches for everything (bilge,blower,acc,etc) but I didn't want those regular boat push/pull switches..... I bought little rockers that light up red but the problem was that the core of the dash is like 1 1/4" and the switches can only mount into a 1/4" depth.... So check it out..... I cut out a section and grinded the area around it ... In the meantime I took two pieces of plexi glass and sandwiched 2 pcs of fiberglass mat inbetween the plexi to make a solid piece of glass to fill the spot for the new switches.... I glassed it in with some strands from the matting now all I need to do is fiberglass bondo over it , sand it out, and cut in my new switches... I'll have some pics later when I get that far.......
    Attached Thumbnails Attached Thumbnails Photo117.jpg   Photo115.jpg   Photo113.jpg   Photo118.jpg   Photo116.jpg
    Sep 2009
    Switches cut in, cleats drilled out, engine cover still kickin' my a$$
    Finished glassing in the dash and cutting in the switches, nice like it..... Also I bought cleats that go flush when not being used, got em' off Ebay... They look great, nice and sleek look.... Engine cover is almost done, hopefull tomorrow then on too the rest of the boat.................
    Attached Thumbnails Attached Thumbnails Photo136.jpg   Photo133.jpg   Photo134.jpg   Photo138.jpg   Photo137.jpg
    Northern ILL.
    Hey thats looking good!
    UMPBA 926 Gas Jet
    Sep 2009
    Been busy working but I got a little time in getting my rear view mirror drilled in and gas vent fitted. Trying to get all the scratches fixed, holes repaired, and any other loose ends before paint.......... Click image for larger version.
ID:	227668Them I noticed a soft spot in the floor and you see what happened next!!! So now I'm gonna reframe/fiberglass this area and frame in new seat suppClick image for larger version.
ID:	227667orts..... Now I'm thinking about possibly making the front seating a bench vs. two seats......... What do you guys think about that??? Pros / ConsClick image for larger version.
    Sep 2009
ID:	227733new floor framed and fitted, ready for glassssssssssssssssClick image for larger version.
  12. #12
    Sep 2009
ID:	228821Ran my wiring for the push button ignition under the D-seat, and speaker wire to the back engine cover, and also ran some wire through so I can pull my new throttle cable in when ready. Started glassing and fiber-bondoing the seams and ran out of material, have to get moving tom.
  13. #13
    Dec 2009
    UP of Mi.
    looking good
  14. #14
    Sep 2009
    Going 2 seats............ I will paint this thing, hopefully before I'm 100..........Glasswork almost done just have to finish up seat tops and working on final touch ups and sanding before it gets all cleaned up for paintClick image for larger version.
  15. #15
    Sep 2009
ID:	230952Just looking some nice temps to get this thing based/intercoat clearedClick image for larger version.
