Results 1 to 13 of 13
10-23-2010, 12:08 AM #1
Single engine 21' Skater .. 15" 280 or 300x/ Promax
Just picked up a 21' skater and Just want some opinions on previous set up's.
I currently have a 15" 280 ROS. (not on the boat)
Or i would have to buy a 3 liter, 300x or promax.
Stickin it on the 21' Skater, Curious to know speeds/ balance/ pro's-con's between the 2 motors on this particular Hull.
This boat WILL see some chop, not just a lake boat so i dont wanna break any transoms
Appreciate any input.
Thanks
Chris
-Summerford STV River rocket, 2.5 15" sporty (sold)
-16' action. 15" 280 - "The flying potato chip" - 100+ (sold)
-1990 21' Skater
-2009 21' Bay Cobia
-15' Seasquirt "tarponator"
-STV EURO drag , 15" 280
10-23-2010, 01:27 AM #2
You buy that beautiful red one? I love my 21!!
I thought about replacing my 260 with a 300, but wound up with a low hr 280 OS. I do love the 2.5's.
I would grab a 20" mid for your ROS.
Mine's got a con box, and runs mid 90's on gps with just me and light fuel load. 40 gallons of gas and four people, 80 flat(this really amazed me). It loves the chop, and handles great.
Been down the hudson(2 to 3 footers)and it handled it ok but wouldn't make a habit of it LOL. Gonna need to get the tanks done this winter, expensive, but I love this boat.
Anyway, I'm on a 6" bob's plate, and running a chopper II 30 worked by Rich @ Leading Edge down there in Bradenton.
Mine needs a 28 or 29 for hard running.
Gets right up, 50 to 70 porpoise but you can get rid of that easy, from 70 up it's awesome!!!
Pics of mine here if your interested http://www.pbase.com/champ3jd/skater_21&page=all
Good luck with it man, I'm sure you'll learn to love it.
And your video is awesome man!!!
'90 Skater 21, 280 OS
10-23-2010, 07:00 AM #3
300
More torque
Dinny Sweet looking rig and great photos.
have you thought about venting the step?
will help alot, getting on plane,w a load
also 86 that Speedo pickup and pickup a GPS speedo you are losing 1-2
there
10-23-2010, 07:05 AM #4
pro max 300 or 300x........Dirk pitts 21 was fast as hell and ran over some pretty decent water with ease with the 15" 300x on it......i was in the boat at 107mph and if i recall correctly 112mph was its best.......
if you have a 280 though it cant hurt to bolt it on and see how you like it.....1984 28 ghost twin 200 Yamah ProVs (SOLD)
1997 21 Superboat Legend 250 VMAXXX (SOLD)
2001 25 Concept CC 250EFI (SOLD)
2002 24 Superboat Step 250EFI (SOLD)
1997 21 Checkmate Pulsare 200EFI Merc (Beater Boat)(SOLD)
1994 20 Hydrasport 225 Optimax (SOLD)
1998 27 progression Twin 225 Mercs (SOLD)
2005 23 Kryptonite 300 Promax (SOLD)
10-23-2010, 07:52 AM #5Junior Member
- Aug 2010
- Bermuda
- 19
Hi is this 21 sold yet it looks real good
10-23-2010, 08:24 AM #6
Chris...15" 300x or 15" 300XS... you should be able to cruise at 100 with the x motor.....
Brent
2009 LCB 2005 300X
10-23-2010, 09:40 AM #7
300X 15 mid = ultimate setup...X inherently more dependable/longer lasting...No ill handling efeects with a cut mid...No slouch with a 280 either...Slap yours on, run it, enjoy it, get some seat time, advertise it in the meantime, upgrade in the off season...Best of both worlds!! Al
24 Skater Twin 220s.... 260s Coming Soon!
10-23-2010, 10:30 AM #8
Black Copy Cat
I would tell Shawn to build you a S.T.R. motor, then you would reaaaaallllyyyy be fast!!
10-23-2010, 12:29 PM #9
Thanks
Thanks for the input guys.
I am gonna keeep looking for a 300 I guess, and keep the 280 on my action for now.
Keep the info coming.
Thanks
Chris
-1990 21' Skater
-2009 21' Bay Cobia
10-23-2010, 12:44 PM #10
10-23-2010, 01:12 PM #11
West systems, w some silica powder, Mix to mayo consistancy
sand the area w 320, take a larger drill bit and slightly enlarge the opening of the hole,
don't drill in. Wipe w Acetone, Use a razor blade to pull a tight coat, of epoxy over holes
go back forth, up down you ll have plenty of time w epoxy. sand between coats
trick is not to build up all at once, tight wipes let dry in 2-3 passes will eliminate most of the sanding.
(Use fast hardiner) West marine sells small kits, you dont have to buy the whole setup.
its easy. Sorry thread hijack
10-23-2010, 01:19 PM #12
10-23-2010, 04:39 PM #13
You can Brush the Gelcoat in a small area and cover w wax paper, let dry
Wet sand and Polish back. (dont forget hardener)
The vent goes in the Back step, helps the boat break free on the way up to plane
by relieving the vacuum pressure created by the hull and water. Will be a noticable difference
on smaller cubed motors. Faster to Plane, wont help top end.
Last off topic post Sorry
