Page 4 of 9 FirstFirst 1 2 3 4 5 6 7 8 9 LastLast
Results 46 to 60 of 123
  1. #46
    Jul 2007
    Upper East Tennessee
    I ground off the wedges and now I'm just waiting for a day warm and dry enough to shoot the primer. The next pics should look a LOT better....
    Got the po old junk trailer fixed, painted and rigged for the boat.
    OK, I got down off the porch and ran with the big dogs....kinda sore now....think I'll just lay here in the flowerbed for a while...
    1976 Hydrodyne 18 I-O
    1969 Allison 15R, 1973 Merc 1500 (project)
    1995 Harris toon
  2. #47
    Jul 2007
    Got the bottom in primer today, Interlux epoxy. Sure shows the pinholes, about a million of 'em. On to epoxy filler and start sanding with 150 again....at least it's getting smoother.
    1995 Harris toon
  3. #48
    Jul 2007
    Sprayed the white Imron on the bottom, had some runs and I'll need to sand and re spray a section on the starboard side, had a mixing snafu. Otherwise looks like all my paint work. "It don't look too bad if ya don't look too close!"
    1995 Harris toon
  4. #49
    Jul 2009
    Maine
    Lookin' good! Nothing like a coat of paint, huh?!
    Rich E.
    17' Action Marine/2.5 Pro Max 200
    "Badges.........We don't need no stinkin' badges........"
  5. #50
    Jul 2007
    Quote Originally Posted by Old_Skool View Post
    Yeah, the 1st color that goes on a project is probably the most satisfying milestone. Thanks, Bernie
    1995 Harris toon
  6. #51
    Jun 2009
    Middle USA
    Bernie, Im real curious how your boat handles without the wedges. I left mine alone because I figured they were there for a reason. But I do have to be working the trim thru the speed ranges because of porpoise. I feel my hop at mid range is directly related to those wedges, but I dont know until I take them off some day?
    Conrad
    L6fan57-88
  7. #52
    Jul 2007
    Conrad, I hope it works OK 'cause the motor doesn't have trim....if it hops I'll be getting NAUTICUS TRIM TABS! I took off the wedges hoping to be able to get the bow up. That is usually not my style since I assume whoever designed the boat was smarter than me, but my Hydrostream porpoised with the hooked pad so I thought I'd try this one the other way.
    Bernie
    1995 Harris toon
  8. #53
    Miami,Fl
    looking good trim tabsthought you could steer throught itRick
  9. #54
    Jul 2007
    Quote Originally Posted by delawarerick View Post
    Rick LOL! If this one chine walks I'll sink it!
    1995 Harris toon
  10. #55
    Jul 2007
    Back on the trailer....
    Another milestone....
    I was hoping I could set the boat up high enough to put a skeg on it without installing a dropped section on the back rail of the trailer but it's pretty high. I'm guessing I'll have to half launch the van to get the boat floated....
    Bernie
    1995 Harris toon
  11. #56
    Jun 2001
    Twin Lake, Michigan
    I took them off my Challenger. They made if feel like the boat was glued to the water. After I took them off the boat runs free.
    Quote Originally Posted by milkdud View Post
    Conrad
    Bruster's Mercury solid motor mounts, details here:
    http://www.powercatboat.com/Bruster/Bruster.html
    I'm been living in fast forward, now I need to rewind real slow....
  12. #57
    Jul 2007
    Sprayed primer on the deck today. More pinholes, more filling, more sanding. Getting close now, once the color is on it I am making a 'glove box' under the deck to help support the section hanging over the bulkhead like I did on the Powercat. Then some filling and sanding on the floor, build the seat box, then re-rig it.
    Bernie
    1995 Harris toon
  13. #58
    Montgomery MN - Abu Dhabi UAE
    Looks great Bernie! I missed that you had flipped it.
    Chet Olson
  14. #59
    Jul 2007
    Thanks Chet, here's a couple pics with the deck in white primer, this is what it will finally look like, sorta.
    1995 Harris toon
  15. #60
    Jul 2007
    Finally found where I had saved a pic of the boat when it was picked up by a friend in Texas for me, shows what had been done to the transom by the previous owner. I guess he wanted to try to keep the transom inner skin?
    Bernie
    1995 Harris toon
