Page 2 of 9 FirstFirst 1 2 3 4 5 6 7 8 9 LastLast
Results 16 to 30 of 123
    Tiger is an 89 ci motor, I don't think you can tell anything more from the casting number.
  2. #17
    Dec 2004
    The word "TIGER" is also on the 93 cubic inch 1100 blocks; I have one with the casting number 836-2485. The main difference between the 89 & 93 cubic inch engines is the bore. The 93 cubic inch engines are 2 15/16" and
    all other Merc inline 6 two-stroke engines are 2 7/8" bore. (89 cubic inch & larger)
  3. #18
    Which ones say Panther?
    125's say Typhoon
  4. #19
    Dec 2004
    The "PANTHER" engines were the 4cyl. 65 hp 650 engines.
  5. #20
    Jul 2007
    Upper East Tennessee
    I'll just keep on calling it the 'mongrel'.....
    OK, I got down off the porch and ran with the big dogs....kinda sore now....think I'll just lay here in the flowerbed for a while...
    1976 Hydrodyne 18 I-O
    1969 Allison 15R, 1973 Merc 1500 (project)
    1995 Harris toon
  6. #21
    Jul 2007
    Got the mongrel painted, just spray bomb work but the cowl and face plate Jim Rineart sold me looks great.
    I like the idea of an aluminum paint on the lower so when the paint blows off it looks better than if it were black, but not sure if I REALLY like the color, too shiny....
    This thing is truly a mongrel. One of the tilt shocks was originally WHITE....no telling how old it is. Since it is an unidentifiable 89 CI block, obviously stock garden variety motor on a hi perf. mid it is really a sheep in wolfs clothing. I am concerned that the noise of the open exhaust may turn out to discourage me from using the boat much. Oh well, I hope I have a few days during winter that I can get out and continue to fair the hull, and be ready to spray paint when it gets warm enough in spring.
    Bernie
    1995 Harris toon
  7. #22
    Dec 2004
    Looking good Bernie!! No one should have any problem telling it's not a Merc.
    Look on the bottom of the carbs for the bore size. The 100 HP Mercs used
    1 3/16" bore carbs up thru 1965 models. The 68-69 models used 1 1/16"bore.
  8. #23
    Jul 2007
    looks like it says 1 1/16?
    1995 Harris toon
  9. #24
    Looking at the 1969 Merc specs ... 1 1/16" carbs on early 1000's ---- 1 1/4" carbs on late 1000's (1000-1's) and 1250's
    1963 specs show 1 3/16"
    1968 spec shows 1 3/32"
    Looks like that was the right thing to do and it has narrowed it down.
  10. #25
    Dec 2004
    Sounds right on the 1 1/16". I was quoting from memory on the 68-69 100
    hp engines. Never saw a 100 hp with 1 1/4" bore except 1000 BP. I have either a 68 or 69 1000 that is original, I'll check the carbs on it.
    Bernie, it looks like you have a 68 or 69 with carb bores other than
    1 3/16.
  11. #26
    Jul 2007
    Thanks guys.
    1995 Harris toon
  12. #27
    Nowthen, Minnesota
    Wow Bernie, That looks great! If it turns out as good as the last two you did you will have an awesome looking boat when your done. Subscribed.
    -Kevin
    1982 Hydrostream Vector
    1982 Hydrostream Vamp
    1973 Hydrostream Vixen
  13. #28
    Jul 2007
    Thanks Hip, just wish I had some more good weather this year. All I can do for the rest of winter is try and get parts together and work on the trailer. Are you gonna have the 'bus' ready next season?
    1995 Harris toon
  14. #29
    Nowthen, Minnesota
    Quote Originally Posted by oldskier View Post
    I am shooting for late spring/early summer. Now that I am all finished with my big move and finally settling in I can get to work on it when the weather is nice to me but have a feeling that nothing will get done until the snow starts to melt but I should be able to really crank it out then and be done with it. Well, Not totally done but it will be on the water anyways.
    -Kevin
  15. #30
    Miami,Fl
    I like that motorwhere did you get that mid? Sound should be sweetRick
