Results 1 to 4 of 4
    longisland ny lindenhurst
    1993 bridgeport mods?
    whats up guys,i got a 93 carbed bridgeport.the block is stock never had any port work done to it.has big bore carbs,crossed drill intake,top pinned pistons.i ran it all summer now im thinking on making it push alittle more power.can i send the block out for port work?i was thinking on getting the exhgust ports larger.can it be done?if so whats the good and the bad about it?can it be turned into a 260?would i have to change anything like the tuner or heads?
    need some help thanks
    16ft superboat
    14ft vixan
    15ft viper
    24ft sleekcraft
    21ft sleekcraft modvp
    18ft action hst drag
    18ft accelerator drag
    21ft redline
    18ft vking yt 300 yamaha!
    Sep 2002
    Panama City Fla.
    The Bridgeport models were not made after the introduction of the 2.5 260 in 1991-92 as far as I know so you may have a replacement powerhead which was built in 1993. These engines did not come with top pinned pistons either to my knowledge??. So I question how that can be?? BUT cutting the exhaust chest and enlarging the bottom exhaust outlets will help. You'll need to cut the heads to gain compression to see much in the way of a power increase. Of course the little things like porting the pistons themselves and opening the rod slots will also help as it is not a single thing that makes an increase but the sum total of all you do. There are a lot of "little" things that will help but whether or not it is cost effective is the overall question. We do all of these things daily. You might call me direct and discuss what you want to do. 850-769-9391
    www.eagleoneperformance.com
    Sep 2002
    If you want the motor to continue to perform reliably, leave it stock.
    If you want the motor to perform like a 260, then get a 260.
    If you want to make a time bomb out of a good motor, start grinding.
    My BP is all-stock with cast side-pin pistons, stock heads, and thick fishin'-motor gaskets.
    87 octane
    8000 RPM w/ 22p
    7750 RPM w/ 26p
    7200 RPM w/ 30p
    Northern/Southern ky
    if it is a real bp motor having the exhaust cut out of it will help. i had one looked like a drag exhaust.. awesome running motor. cut the heads to 150 lbs comp run 93 oct fuel, and rock on!!!doesnt effect reliabilty. we all should be running the best fuel you can get at the pumps anyway. JMO like pyro said they run good stock, but it will never b a 260.
    93 xr 2001 drag with a 15" drag
    92 xb 2002 comp with a 15" drag
    R.I.P. Phil "rpm racing" Watch over the rest of us my friend.
Diamond Marine
