Results 1 to 5 of 5
Thread: Evinrude Etec 150 HO
10-06-2010, 03:34 PM #1Junior Member
- Sep 2006
- 27
Hi everyone!
Does anyone know at what rpm the engine is limited? The spec sheet says full throttle rpm range is 4850-5850 but today I heard it rev way over 6000 up to 6700. Could that really be the case?
Thanks // Jon
10-06-2010, 04:08 PM #2
i believe 6250 is the hard limiter... shouldn't go any higher than that. Id check your tach
Dan Cario
1994 STV Mod-VP w/225HO Ficht Evinrude
1987 22' Velocity w/225HO Evinrude E-Tec
10-06-2010, 05:19 PM #3
If it made it to 6700 it'll throw the "you ain't doin' that to me" code 57 ECU shut down, and you'd be on your way to the dealer with a motor that won't start.
10-07-2010, 12:09 AM #4Junior Member
- Sep 2006
- 27
Thanks à lot!
11-02-2010, 04:06 PM #55000 RPM
- Nov 2007
- London, UK
- 257
I know plenty of the analog tachos to be 500rpm out, this seems to be a common amount to be faulty with.
