Results 16 to 30 of 31
Thread: Setback theory
10-07-2010, 11:38 AM #165000 RPM
- Aug 2009
- Azle Tx
- 594
That boat looks good. I was picturing something with less freeboard
10-07-2010, 12:00 PM #175000 RPM
- Norway
- 935
- 61
- 13
- 353
- 182
Hi!
The freeboard is fine, but there are drain hulls through the transom who concerns me. They are mounted a little low, so when I have twins, the water tend to come into the splashwell. However, I hope with the 350 sci that the water stays outside. With the Promax 300 with 7,5 inch setback, the transom was 3 inches higher in the water. So I hope we will be somewhere in between. It would make my day a little easier
Cheeers, Toffen
10-07-2010, 12:59 PM #185000 RPM
- Aug 2009
- Azle Tx
- 594
10-07-2010, 01:21 PM #195000 RPM
- Norway
- 935
- 61
- 13
- 353
- 182
Hi!
Whats ball scuppers .... Sorry, I am from Norway ! Thanks
Cheeers, ToffenG
10-07-2010, 04:06 PM #205000 RPM
- Aug 2009
- Azle Tx
- 594
This is a ball scupper its like a check valve lets lots of water out and very little back in. The steeper the angle of your transom is the better it works.
Is the 350SCi a straight 6 too?
10-07-2010, 04:43 PM #215000 RPM
- Norway
- 935
- 61
- 13
- 353
- 182
Hi!
Aha Thanks!
350 sci is an inline 6 engine as 300 Verado. Approx. same weight as well. Can be delivered in 20 inch midssection.
Cheeers, Toffen
10-07-2010, 05:05 PM #22
7 to 3pm 5 days a week
Custom Fiberglass and Paint
In Business since 1984
for sale
10-07-2010, 06:33 PM #23Screaming And Flying!
- Jul 2004
- Connecticut
- 6,007
- 464
- 168
- 910
- 951
Toffen, there is no need to guess. Get a sling under the boat as it is rigged now and determine the current C of G when full of fuel. If you like the way the boat handles and lands then you can attempt to match the C of G or make the needed adjustments while on the sling.
10-07-2010, 07:27 PM #24
Good lookin boat!
10-07-2010, 07:37 PM #25
cool boat long and lean must cut through the rough stuff like a knife
10-08-2010, 10:17 AM #26Junior Member
- Mar 2009
- WARSAW VA
- 18
Toffen I dont think your going to see the performance that you would see if you just mounted 2 300XS thats what we are seeing in the center console world. If your purely after speed that is. There is a guy on the hull truth with quad 350's who rumor has it has been trying to accomplish what another boat identical to his has been doing with quad 300xs. I want to say the quad 300xs boat has worked the lowers or anything. The 350 is going to kill the 300 in the hole shot but in top speed is going to fall short.
10-08-2010, 04:01 PM #275000 RPM
- Norway
- 935
- 61
- 13
- 353
- 182
Hi!
There are several boaters out there who have tested both; the 300xs and 350 sci. In the beginning with the 1st gen lowr unit, the 350 sci was 3-5 mph faster than the 300xs. With the 2nd gen lower unit it was only 1-2 mph faster, mainly due to the new gearcase being larger. The 2nd gen did not like to be jacked either. Now the 3rd gen gearcase is coming, and hopefully it will be a little faster than the 2nd gen. I agree with you that it will not be much faster with the 350 sci, but the Verado has 3 years warranty in Norway. The 300xs is now likely to drop to 1 year. And 300xs need 96 RON and 350 sci needs 95 RON in Europe.
There is no question that the 350 sci is a strong motor. Most likely 375 hp. But the 2nd gen lower unit has made it slower than when it first was released. Mercury Racing will announce a new Poseidon gearcase in November, and I hope then to see if this gearcase can be jacked higher / being faster.
Cheeers and thanks, ToffenLast edited by Toffen; 10-15-2010 at 08:43 AM.
10-08-2010, 05:04 PM #28
Toffen - there are several things that affect performance with the use of a jack plate or set back arrangement. it sounds like you are referring to the application of a 'set-back' specifically.
The reloaction of the engine further aftward does change the static longitudinal CofG of the hull. this does have an effect on performance, but not a significant one, in itself.
More importantly, the aftward setback of the engine (and the location of the lower unit and propeller) affects the "dynamic balance" of the hull. This is the effect of all of the acting forces on the hull - hydrodynamic lift, hydrodynamic drag, aerodynamic lift & drag, and all the static weights (forces) of the hull and payloads.
Of significance is that the Dynamic balance of the hull is different for each velocity of the speed range. So, changing the setback of the engine also affects performance differently at each velocity of the hull.
There are a few articles on how you can do these calculations manually on my website, if you are interested in more detail.
10-14-2010, 06:31 PM #29
I owned a Glasstron GT150 (14.5 foot hull) with a 115 Johnson on it.
the water came in and out of the drain hole a lot, I never worried about it.
the hull weighed about 600 lbs and the motor + gas tank + battery weighed about 400 lbs. so it sat a little low in the water.
the rub rail was submerged at the transom .
allso when you let off the throttle suddenly the wave allways came completely over the motor, so the motor allways went under for a second or two.
I actually had a mullet fish laying in the splash well at one time and a sand dollar on another occasion.
Oh how I miss that boat........
HarryLast edited by Old Sloppy; 10-14-2010 at 06:37 PM.
1994 Baja 170 Islander with Mercury o/b
10-14-2010, 07:55 PM #30
I have done this before and it works great. Also what Jim Boat has said is the most note worthy. Theres very few people that have studied dynamics of hulls and power more than Jim on the planet. He has several books on this subject. I would call Jim to discuss this further to save yourself some setup time.
She sounds like what the doctor ordered for a power plant. Your hull will take on a whole new dynamic in performance. My not be quite as fast as with twins but will be a pleasurable change in sound and torque!! Cant wait to hear how she goes.
