Results 1 to 15 of 41
09-17-2010, 07:30 AM #1
Let's talk EFI Fuel Pressure Issues
Here's what I've got..........
Merc 250 EFI/Brucato SVS/Bosch 044 EFI Fuel Pump, fresh injectors running 100% pre-mix (no VST), Mallory EFI Pressure Reg. w/Vac Boost Port hooked up to the intake.
Here's my issue.........
EFI Regulator at idle is set to 38-40 PSI w/vacuum boost port connected. The pump is very capable of pushing 75 PSI @ 80 GPH minimum, why is it that my fuel pressure drops off 8 PSI at WOT..................? All fuel line is -6 hose (3/8 ID) and new.
09-17-2010, 11:15 AM #2
how's your'e voltage at the pump?
09-17-2010, 11:36 AM #3
09-17-2010, 03:24 PM #4
i'd be curious to know how you have it wired, always use a relay, you can come off the battery for main relay power w/ an inline fuse holder, luckily you haven't blown it up, also, what do you have for filters? alot of people don't realize that there are 2 different merc spin on filter/separator elements, one is a 10 micron, one is a 20 micron which is what you want.
09-17-2010, 03:54 PM #5
Charlie,
This just started. I've run before with the cowl off and didn't notice a pressure change. I'm wired with a relay, fused but not drawing directly from the battery. Previously the boat had a Holley Pump in it when I bought it and when I changed it out to a Bosch I just used the same power supply wire and relay. I'll have to back track the wiring to find the source of the power. As for a filter, it's a NAPA GOLD water seperating filter new this year. I'll look at it this weekend and see what's what..........thanks.
09-17-2010, 05:52 PM #6
How is the check valve in the fuel tank? I've had several this year that were "stuck" and limited the fuel to the motor under WOT. Removed the valve, cleaned it, done.
Bruster's Mercury solid motor mounts, details here:
http://www.powercatboat.com/Bruster/Bruster.htmlI'm been living in fast forward, now I need to rewind real slow....
09-17-2010, 05:56 PM #7
09-17-2010, 05:59 PM #8
Is the pump pulling the fuel through the water sep filter?Do you have a pre pump feeding the high press bosch pump?Those Efi pumps are not designed to pull fuel,it has to be fed fuel at the bottom of the tank,which is hard to do in a marine application,so you have to have a low press pump with some kind of air separator like the stock VST tank.
09-17-2010, 06:32 PM #9
09-18-2010, 09:24 PM #10
hey gary i would say the pump is going out. i have had them hold 60 lbs at a idle. drop the hammer and the pressure falls off by 15 lbs when they start going bad.
93 xr 2001 drag with a 15" drag
92 xb 2002 comp with a 15" drag
R.I.P. Phil "rpm racing" Watch over the rest of us my friend.
09-19-2010, 12:24 AM #11Junior Member
- Sep 2001
- GLADSTONE,MO.
- 28
As the pumps get a lot of hrs. on them they will fall off a couple lbs. We found that routing the return line back to the "in" port on the fuel & water seperator it will help hold pressure up. It also keeps the seperator full of fuel, so no air gets in the fuel feed system. Been running this set up since 1988 with no issues. I also use an automotive in tank low pressure to feed the other "in" port on the seperator. Works great.
09-19-2010, 03:20 AM #12Supporting Vendor
- Sep 2006
- Key Largo, Fl
- 3,272
- 215
- 30
- 585
Boatbuff, should air inter your system from whatever source where does it end up? If you route your return line to the filter body any air that gets in the system seems doomed to just re-circulate through the fuel system and never return to the tank,what am I missing?Chris
09-19-2010, 07:10 AM #13action mobile marine, 772 528 0754, dealers for aces fuel products,wolf efi, pro marine,latham and gaffrig/livorsi. we build gearcases and modify them(3 litre) to ratchet, and powerheads as well. 21 skater/3 litre wolf efi 113 mph the engine build http://www.screamandfly.com/showthre...-3-litre-build
09-19-2010, 08:27 AM #14
You have to run a return back to the tank from the filter seperator to rig like that and even then its not a 100 % air free but it will work on a consumer type engine.
[SIGPIC][/SIGPIC]
09-19-2010, 10:05 PM #15Junior Member
- Sep 2001
- GLADSTONE,MO.
- 28
Don't know if I am lucky or what, but with the in tank pre pump, to the in port on water seperator, out line to the Bosch high pressure pump, to motor. Fuel return to the in on the water seperator. Holds 39lbs. of pressure and has been running the 2.4 EFI high performance motor 7400 rpm since 1988. Whats running the return line to the tank going to do for me??
