Results 1 to 15 of 30
    Mar 2010
    Hendersonville TN
    260 offshore mercury racing parts
    Most of these parts were bought of this web site..we were going to build one bad 260hp boat motor but due to health reason cant afford to anymore...so i am listing all the parts i have for sale..i can send you pictures upon request..please feel free to email or cal me with any questions thanks mike 615-714-5921..
    heres a list of what i have:
    -2.5liter sportmaster small shaft, right hand, 1.87 gear ratio. swept skeg. had the lower part of skeg repaired npthing major, just had serviced..complete tear down everything checked out good, new seals installed. test run on my allision and works great..$1500 o.b.o. ......sold
    -cle internals including shafts....make an offer
    - n.i.b bosch 984 fuel pump....$175
    -mercury cowl, pan and skirt. had cracks repaired, new paint and decals..looks great..
    $350 ******SOLD**********
    -96 big bearing 260 block front and back matching halves....just back from jim ruck 1
    new sleeve and diamond hone no welds or holes this was a low hour block that lost # 5 inj the nic is in great shape not thin ...ready to go..$1800 o.b.o........sold
    -set of six new mercury racing pistions w/ rings and stock pins..top pin by morrels,
    angle cut and balanced...$175 each.........sold
    -light weight wizard wrist pins new...$180 for set.......sold
    -small rods balanced by JSRE never used..$500 o.b.o.
    -reed block modified by JSREwith one inch spacer and all linkage...$500
    -light weight flywheel..$375 sold
    -9 ring 300 drag crank just got back from marine crank shaft..polished, straighten and
    checked out ok by david..ready to run never used...$600**********SOLD************
    -billet 7 pedal reed cages w/ boysen dual stage reeds w/ one extra block...$275**********SOLD**************
    - JSRE modified air horn w/ ecu bracket and fuel rail and regulator...$550
    -6 mercury racing coils with blue wires...make an offer*********SOLD**************
    -94 260 offshore mid..its apart, everything has been sand blasted and repainted except clamp bracket...new bushing and seals, steering shaft reinforced. single hydro ram. can reassemble for a small fee or sell as is for $1400************SOLD*************
    -new wizard tuner and one used bobs tuner make an offer..
    just trying to recop what i have in the parts...maybe able to negt. prices on some of this stuff..may have other parts this what ive gathered up right now just give a call and ask i might have it thanks mike 615-714-5921.
ID:	216955   Click image for larger version.
ID:	216954   Click image for larger version.
ID:	216958   Click image for larger version.
ID:	216956   Click image for larger version.
    May 2005
    Does the CLE internals have the pre-load shaft and do you have any pics of the Cowl ?
    Mar 2010
    Hendersonville TN
    260 parts
    No preload send e mail and can send pics thanks
    Dec 2004
    Tennessee
    Have a pic of the offshore mid?
    Mar 2010
    Hendersonville TN
    Yes have picks send pm and will send but need to call to explain every thing that was done to this mid was in middle of complete rebuild on it when got sick to much to type on pm and I am not that good at it thanks mike
    TX......somewhere?
    Pics of tha block
    allysun260@sbcglobal.net
    Thanks............T
    May 2010
    Springfield, Ga
    I have a question what's the difference in a 2.5 200 block and a 2.5 260 block?
    Mar 2010
    Hendersonville TN
    Port timing port size intake everything
    chester va
    pm sent
    Jul 2009
    Racine Wi
    Hi Mike, talked with you early today. Could you please send me some pictures of the lightweight flywheel BrandtRacing@gmail.com
    Feb 2005
    Orlando, FL
    I would like the reed cages and reeds and the coils and wires. We talked yesterday. I will give you a call again today.
    Scott
  12. #12
    May 2001
    Panama City , Florida
    Sent you a PM on the Crankshaft.
    [SIGPIC][/SIGPIC]
  13. #13
    Nov 2009
    NY
    You have a incoming PM.....
  14. #14
    May 2001
    Hey Mike .Here my e-mail address. johnnyracer37@comcast.net
    [SIGPIC][/SIGPIC]
  15. #15
    Sep 2009
    n.y
    i am interested in the heads.can u please email me pics of the heads .steig1029@yahoo.com
    thanks,john
    24-Skater "substitute found"
Spinelli Props
