Results 1 to 15 of 16
Thread: Adding setback or work prop?
08-08-2010, 02:34 PM #1
Do you guys think adding 2 in more to my 6 in hydraulic jackplate will make a noticeable difference in bow lift. I was running 12in before and that was doing the job but it was too much stress to my transom and im afraid that i will crack it again even though now its 1/2 in thicker and new. I have a 26p chopper and also a worked 27p trophy and both props are not lifting the boat. The motor is about an inch below the pad. i would try to post some pictures laterLast edited by bluecheckmate; 08-08-2010 at 03:28 PM.
Reaction 19ft
08-08-2010, 03:16 PM #26000 RPM
- Oct 2009
- Gonzales, La
- 1,085
- 114
- 69
- 218
- 355
Have you considered a Tempest Plus? I've heard it's an extreme bow-lifter, with some people complaining about too much bow lift.
08-08-2010, 03:28 PM #3
no i haven't tried that prop yet. Someone else told me about that prop.
Reaction 19ft
08-09-2010, 12:30 AM #4
Any good prop shop can make each of those props make more bow lift.
Carter Powell
08-09-2010, 12:39 AM #57000 RPM
- Apr 2008
- Washington N.C.
- 2,154
I agree with Carter, but if your boat is bow heavy you need to move the CG back.
08-09-2010, 07:18 AM #6
08-09-2010, 07:55 PM #7Team Member
- Lake Coochiching, Ontario
- 7,746
- 271
- 485
- 1569
- 6 Post(s)
You could try lowering the prop. Lower props have more bow lift. 1" below might be too high for your speed/boat weight. Lowering is a relatively easy and cheap change.
08-09-2010, 08:22 PM #8
im with David lower motor 1 in. add cup to your wheel Peace DS77
Steve Smith
Shepherdsville, Ky
502-693-3273
Click Link to Visit our Website at
http://www.sdspropshop.com
08-10-2010, 06:40 AM #9
I cant lower my motor any more due to the fact that the transom is now a 25in b/c i had closed off the transom. Do you guys think if i had 6 more inches which will give me 12in in total do you think that the motor will be getting enough water by then?
Reaction 19ft
08-10-2010, 06:48 AM #10
The further you go back the higher the motor will be. JMO
08-10-2010, 08:52 AM #11
08-10-2010, 10:58 AM #12
I just finished talking to hydro dynamics and there going to make me some 4 in setback brackets with a 4 in drop and i can put my jackplate on it. I should be fine with that
Reaction 19ft
08-10-2010, 12:25 PM #13
Shouldnt hurt, I was going to say Can't hurt, but ya never know, setup is like a woman, just when you expect it to do one thing, it does the opposite.
08-10-2010, 12:28 PM #14
08-10-2010, 01:15 PM #156000 RPM
- Oct 2009
- Gonzales, La
- 1,085
- 114
- 69
- 218
- 355
Call me crazy, but in the picture up top, the prop centerline already looks WAY low versus the pad.
