Page 4 of 5 FirstFirst 1 2 3 4 5 LastLast
Results 46 to 60 of 64
  1. #46
    Jan 2008
    CYPRUS
    I drilled the hole exactly over the throttle body and it's 3" wide.
  2. #47
    Jul 2010
    Haughton, La.
    I talked to Eric Simon a couple of days ago about the current ecm upgrade for the 225 Pro XS and he told me that in maybe 6 months from now he should have a newer mod with better results. I'll keep my fingers crossed and hope for better preformance gains.
  3. #48
    Jan 2008
    CYPRUS
    I had my ECU "upgraded" one year ago (not in the USA) and i didn't see any difference.
    I had my ECU upgraded again a few months ago and i am still trying to see some more speed maybe i had a small gain but not something i can say for sure.I am still trying propellers .
    I think the ecu upgrade is not enough by it's self maybe the engine needs some more air.
    Still trying , i'll be back with the results.
  4. #49
    Jan 2005
    Ive been keeping up with this thread as my Pro XS warranty will soon expire. There was some comments made where too much air into these engines will create a lean condition where they are already running lean.... at what point will opening up the breather box/air inlet hurt them?? I mean, the air is not being rammed into the outboard rather it is sucking the air in.... what gives with that???
    Support Our Troops!
  5. #50
    Naples, Florida
    Jan 2005
    Todd,
    That video is really not in the same category as these two mods. We are talking about two simple mods that anyone can do. The outboard in that video has been modified tremendously.
    Support Our Troops!
  7. #52
    Naples, Florida
    There are a few more mods I understand but I posted it just to prove that it does increase HP without decreasing Torque. I have the dyno sheets that tell what each mod did to increase HP. I'll dig them out and post the results.
  8. #53
    Aug 2009
    Azle Tx
    Quote Originally Posted by Todd D View Post
    Oh Todd don't tease me.
  9. #54
    Naples, Florida
    Official results: This is on the Hydro tech powerhead dyno. After each mod they made a run!
    Stock powerhead 294.7 @ 6,000 rpm
    light flywheel/ecu 306.2 @ 6k
    hydro tech tuner 313.6 @ 6K
    blueprint block ports 320.1 @ 6K
  10. #55
    Cape Coral,Fl
    Just so I am thinking about this right. Is each modification tested seperately or is it cumlative? Or another way to say it is; Was the hydrotech tuner tested as a stand alone unit (+18.9 hp) or together with the ECM/flywheel (+7.4 hp)?
  11. #56
    Naples, Florida
    It was cumulative. Each mod added around 10hp towards the total.
  12. #57
    TODD D. And im guessing these dyno runs were made with no air box installed on the motor? In your opinion will modifying the factory airbox like described in this thread add any HP or performance to an otherwise stock optimax merc? Any thoughts?
    Naples, Florida
    Not sure it would help the airbox on those has a big hole in the port side. I know that Don Weed with European Marine suggests not to run you opti with the cowl off in fear of leaning in out. I have seen were a few different people made a ram air intake for one???????????
  14. #59
    Nov 2002
    Tucson, AZ
    Was this a stock 250XS that made 294.7 out of the crate? Was it driveshaft or propshaft horsepower? Either way it is impressive.
  15. #60
    Thanks for the reply... Many different ideas..... sounds better with the hole at least, optis are too quiet...
