Results 1 to 7 of 7
Thread: Problems with hyd. jacking plate
08-02-2010, 07:29 AM #1Junior Member
- Jan 2010
- chesapeake va.
I a have 20 ft hst, 2.4 Bridgeport,,I have a hydraulic jacking plate made by land and sea performance, I am having issues with the pump losing pressure and the motor dropping, can any one help me with information on where to send to have it rebuilt?
08-02-2010, 10:29 AM #2
ive already been through this... no one around me would rebuild it... i ended up buying a detwiler, after much research the land and sea sucks and have no parts availability. i have an hst as well post some pics theres some other hst owners here and alot of good information.
Hope for the best, expect the worst...
08-02-2010, 12:08 PM #3
I fixed mine on bolth boats 2 different pumps, one was a o-ring, other brushes in the motor. As Hst714 said some haven't been able to repair theirs.
08-02-2010, 01:33 PM #4
i was able to repair the leak down issue with an oring as well then the motor quit and i gave up on it after not being able to find parts. someone already pm'med me about mine if he doesnt take it ill let you know if your interested maybe you could make one good one out of both mine and yours...
08-02-2010, 02:09 PM #5Junior Member
- Jan 2010
- chesapeake va.
I am interested, maybe it will get me through the season by fixing it.I looked at the detwiler, how do you like it?
08-02-2010, 07:03 PM #6
i love mine, i did have problem with the exact-a-dial would just not respond sometimes but they are sending me a new control module for free so i cant relly complain the operation of the jack plate itself is flawless and no matter how far up or down it is strong. the design of the land and sea is poor all the way up its weak because less material is in contact it slides out of itself...if you know what i mean
08-03-2010, 03:25 PM #7
i had the same problem with my land and sea. tore it apart and couldnt find parts so i replaced it with a cmc. land and sea jackplates are junk. although i will admit it goes up and down much faster than my cmc.
1984 Nordic pickel fork. 2.5L 245 carb, CLE. top speed: 95mph with more to go
