Page 2 of 2 FirstFirst 1 2
Results 16 to 20 of 20
    Oct 2005
    miami fl
    The 300x is for sure more powerful. Shauns reads definitly make more power on top i gaind 400 rpm on top from stock 250 reed cages the throttle body doesnt make that much difrence on its own being that the reeds on a stock motor just cant swallow the (cfms) extra air. The most bang for your buck that will blow your mind will be a lightend flywheel and a hydrotech tuner shaun can get all of that done for u also very important to get the most from the tuner u need a simon poppet diverter u will remember me once u do these 3 things
    [IMG]pictures[/IMG]
    21 stallion 300x (sold) 92 mph
    21 spectre twin 2.4 efi ( R.I.P.) 106mph
    21 xtreme cat 300x ???
    24 pantera open fish twin 2.4 efi ??
  2. #17
    Daytona Fl.
    I've had dozens of 300's on 21 Liberators. They both run well, but I get another 1-2 mph out of the 300xs. The midrange seems stronger on the 300xs. The 300x turns more rpm, so you can run a smaller prop which may give you more acceleration. If you run the same prop on both, the XS will be a bit faster. That's on a 21 Liberator. On other boats it may be different.
    Check out my new website. (IN PROGRESS) liberatorpowerboats.com
    Things owned. NOTHING!!
    Visit My Liberator and Checkmate Boats Website
    Rent our Log Cabin in Pigeon Forge, TN. http://www.vrbo.com/419205
  3. #18
    Oct 2005
    Shaun is building me pair 3 litre with 3.2 xs cranks , close to 370 hp , will keep posted as my 32 skater will be ready spring 2011
  4. #19
    South of Boston,Ma.
    I went from '98 Pro Max 300's to '03 300X motors on a heavy MAGNUM Sedan 71 GPS to 79GPS Guido
  5. #20
    Quote Originally Posted by Liberator*21 View Post
    Wonder if anybody has been playing with reed cages trying to get a little more past them
    There's probably a guy in Key Largo thats smart enough to bring the reed valve into the next phase of development ..
    Lets say there were some flow bench developed , billet blocks available , do you think there would be a market for them ?
    The stock blocks with every other rib removed have proven to pick up airflow on the bench , but in the real world there may or may not have the time to open and shut the larger , heavier and stiffer reed to take advantage of the added volume of media ( air / fuel and oil)they have the potential to blow once open and stable ...
    Once winter is over in a few weeks .. maybe we can have some solid data to bring to the table ...
Simon Motorsports
