Results 1 to 2 of 2
    Jul 2007
    Upper East Tennessee
    Timing a 1963 I6 Merc
    A friend of mine on the Powercat site has a 1963 I6 100 HP Merc and has some performance issues. A discussion has been going on as to whether it can live on modern fuel with the timing set to factory spec. (32.5 degrees). Apparently the early I6's had low dome pistons and some say it will run on E10 fine with the factory timing, I think it should be retarded 5-6 degrees to live on ethanol. Any opinions?
    Bernie
    OK, I got down off the porch and ran with the big dogs....kinda sore now....think I'll just lay here in the flowerbed for a while...
    1976 Hydrodyne 18 I-O
    1969 Allison 15R, 1973 Merc 1500 (project)
    1995 Harris toon
    Jul 2008
    Key Largo, FL
    Bernie,
    I know the fuel now has less "energy" I would be pulling timing, but I hate breaking stuff. The 2.4 EFI bridgeports are a great example of this...
    16.9 Action W/ 135
    * Sweet tooth suicide*
    17 Motion W/250 XS
    *Madness*
    Quote Originally Posted by GDM View Post
    in nasty bay chop the ride on a small v bottom sucks , in sloppy conditions a cat goes right over it like a perfectly aligned rolls royce and the v is like a daewoo with 4 diffrent height tires and bent control arms
