Results 646 to 660 of 848
Thread: *** SPY PHOTOS*** ETEC Drag
12-13-2011, 11:12 PM #646
12-13-2011, 11:15 PM #647
12-14-2011, 11:06 AM #648Banned
- Oct 2009
- cold lake
- 165
That is funny and about as truthful as riverman's last comment, I went for a slalom run november 27 and for a cruise on sunday.
12-14-2011, 11:07 AM #649Screaming And Flying!
- Oct 2003
- Cobourg, ON
- 7,194
John, here in Winnipeg winter has been officially cancelled. Sorry.
12-14-2011, 11:09 AM #650Screaming And Flying!
- Oct 2003
- Cobourg, ON
- 7,194
12-14-2011, 11:14 AM #651
12-14-2011, 04:02 PM #652
Cute lil Musky.
335lb. Vector, 750lb. Ventura II
Hydrostream Addict Hot Evinrude 200 crossflow
12-14-2011, 05:43 PM #653
I had my usual pile this season of grenaded compressors, non functional DI injectors, boxes of spark plugs, reed blocks missing reeds, three power heads with no core value, etc.
On the e-tec side , replaced two injectors and an emm rebuilt due to a faulty water in fuel circuit.
12-14-2011, 06:11 PM #654
I would like to see a number put on the failures due to un-trained techs/mechanics. I pulled down a dead Ficht I bought that had a fuel line pinched completely closed behind the starter. Owner was sold a new Yamaha. Fairly confident previous owners "mechanic" confirmed that Fichts are crap.
Pulled down a dead, carbed looper that had new enough Wiseco's in it that all but the dead one would clean up and pass as new! Never made it though break in. Pretty sure that "mechanic" would have confirmed what crap Wiseco's are. Nothing to do w/his not knowing to add clearance for extra expansion of forged pistons
A little slower at blaming a brand these days. Not doubting your reports Saneo, just seen so much bogus work done on all of them you have to wonder how much is factual and how much is someone repeating what he was told or read.I'd rather be competitive w/junk I built in my garage than win w/stuff I bought.
Checkmate 16' 140 Johnson
Laser 480 (?) 21' w/GT 200
24' Sonic w/twin 250 Johnsons
12-14-2011, 06:19 PM #655
Being an outboard fanatic, I've had many brands including Martin, OMC, Merc. etc. they all have good and bad points, just gotta live with them.
12-14-2011, 08:23 PM #656
I have an 04 175 ficht with factory powerhead and mid (confirmed by dealer). Totally unmolested commercial motor with 1380 hours on it still has PERFECT compression. When I came to pick up the light weight jack barsh powerhead from you I had that 175 ficht 98 (the bad ones ) in the bed of the truck with 2280 hours on it it still to this day has PERFECT compression but his mechanic said it needed a new computer ~500 from DFI I got it home and had it running in a half hour needed nothing but a cps. Two other 175s (the bad motors that put OMC out of business) 99s are on my buddies 21 paramount have perfect compression and run like a Swiss watch... I love the yami/4 stroke salesmen they keep me in business
12-15-2011, 11:17 AM #657
I ran the dog poop out of my 2001 ficht 150 85.6gps on my ltv and it had close to 300 hours on it with 50% wide open running with never a cough, Matt
12-15-2011, 04:25 PM #658
I worked at an OMC/BRP dealership in the early 2000's and I saw a few issues with the earlier Ficht motors. Most of the old "they catch on fire" complaints were due to crappy hardware and mounting brackets on the injectors. Once they were updated, that problem disappeared. We did however, have to replace quite a few of the older computers while still under warranty. Another bug that has since been straightened out by BRP. I am an OMC guy but I saw quite a few customers get a bad taste in their mouth. Especially when they had more troubles with their new Ficht motor in 1 year than they had in 10 years with their "old reliable" Evinrude carbbed motor.
12-15-2011, 04:34 PM #6597000 RPM
- Jul 2001
- Antioch IL
- 2,722
The original DI drag was a 99 ficht..........first powerhead was a 3.0 modified into a 3.3........it had piston issues..........then we went to the 3.3 in 02..........still using the 99 emm and components.......only issues were the pistons holding up at higher rpm............when they went to the last version nasa piston......there were no more issues...........had one cps fail...........and.........a stator mounting position issue..........that was fun to find........one of these days im gonna drag that back out and run it again
WET PICKLE RACING
The "UNracerxOFFICIAL"
Home of the fastest Emission Outboard
Motors on the planet
12-15-2011, 08:51 PM #660
You @!#$%$@'ers have all the fun! Thats really cool to hear i did not know that, I know the etec injectors will turn up but will the ficht injectors limit rpm in that case?
I have seen the HIGH (<-- yes its capitalized and bold) hour ficht pistons crack the skirts off of them. Then the skirts get pulled back into the front half of the block where the big end of the rod blasts them through the block (and or into the bottom of the above/below cyl) and yes they still have good compression
The etec pistons have obviously fixed that issue.Last edited by baja200merk; 12-15-2011 at 08:53 PM.
