Results 1 to 10 of 10
    Courtice, Ontario, Canada
    ETEC Lightning gearcase?
    Does the lightning gearcase that comes with the HO's have a low water pickup to allow higher engine heights?
    1996 Allison GSE /200XS
    1977 Hydrostream Ventura / 150 Mariner MAG III
    Dec 2008
    dallas georgia
    it is a basic style like the bobs combo cones that have the 2 pickups on the sides,no it does not have a true low water.
    Tasmania Australia
    You can get different size intakes to improve water pick up.
    There is 3 different sizes available.
    May 2006
    the newer Lightning gearcase has the water inlets positioned lower than on the original Lightning model.
    Also the shape of the "bullet" directs more water flow into the inlets which allows a higher transom height for more speed.
    Dec 2008
    Buchanan,TN
    uh
    Think under tests it did ok to 1 in under the pad,as for the speedo hookup in the nose its a gimmie,if removed its a water pickup.
    Ever see a racers mod taped higher holes.Note anything done concerning wp should be monitored via a gauge.
    My aftermarket runs pad level quite well,at 28 psi. Id keep that L2 gc at 15 psi,in turns might lose a tad.
    Columbia, SC
    Why couldnt you just direct the water from the hole to the speedometer to the Ph to get more water to it.. Seem like aneffective way to add more water for pressuer?
    Mar 2009
    Sydney
    Quote Originally Posted by gmst2 View Post
    hey mate do you know where to get these intakes from.
    Evinrude dealer?
    Is that your boat in ya pick with an ETEC?. Interested to know roughly what engine height your running and which pickups.
    21 Superclass
    2010 E-tec 250HO
    Force seeking missiles
    Tasmania Australia
ID:	215210Click image for larger version.
    Evinrude dealer?
    Yeah, Evinrude dealers will have them, they are a stock item for the HO's.
    Pretty sure the standard fit up is High Flow but there is 2 other options. We have fitted the Ultra High Flow to our 250. Been able to raise the motor an extra 35mm and still maintain 20psi.
    The boat in the avatar is a Concept 1850. Ran it with a 225HO ski racing and even did a couple of Offshore Powerboat races in it. We are now running a B23 Bat Boat with a 250HO in the Offshore series.
    May 2006
    Here is a chart of the optional water inlet screens.
    The Magnum ( M type ) gearcase, the M2 and the L2 gearcases use the same part number screens.
    http://rides.webshots.com/photo/2301...91848696nfnUcS
    Mar 2009
    Sydney
    Evinrude dealer?
    good stuff. what sort of speeds you getting out of the bat boat?
    I'm interested in the ultra high flow pickup just as an option for a go-faster setup so I can raise the motor with less risk.
    what are you using to monitor water pressure?
    21 Superclass
    2010 E-tec 250HO
