Results 1 to 10 of 10
    Jul 2009
    new iberia, la
    280 trims up on its own
    When i got home from work yesterday i noticed my 280 trimmed all the way up...and i mean all the way, crushed the fiberglass cowl on the boat and warped the hell out of the alien on the motor...i got it trimmed down but it wouldnt trim up again with any of the 3 switches(on the motor,shifter and wheel) jus clicks....i disconnected the wires from the trim pump to the battery but the pump still had power going to it...i dont know how....any ideas?
    Sep 2009
    Santa Rosa, California.
    Man.... Sorry to hear about the damage, that sux..The trim relays at the motor get their switching voltage from the tirm switches around your boat. Any one of your switches could be faulty. I had a wire fall off a switch terminal and lay accross another and cause this problem. That dosen't completely rule out a relay since it could be shorted at the trim motor side. That would normally result in the motor running constantly and only disconnecting the cables at the battery or removing the relay would stop it.
    Steve Schefer
    shreveport,la
    This is another reason to have a battery cutoff switch in the boat that cuts power to everything when you come out of the water.
    Erik Kiser
    Jul 2009
    new iberia, la
    I understand your point about the battery cut-off switch but that doesnt solve the problem while im in the water running the boat
    Mar 2004
    Newaygo, Mi.
    I had the same problem quite a few year back when I bought my first Mirage with the new Mach CRT (cordless rotary trim) system. A brand new boat (never in the water). While driving it home for the first time, I looked in the mirror and saw the motor trimming up on its own. By the time I got the truck stopped, the engine had crushed the rear cowl on the boat and cracked the heck out of the engine cowling. To make a long story short, the CRT wheel had a short in it from the factory (wires were pulled too tight). It was an easy find and fix for a good electrician. Mach didn't warranty anything, nor cover any damages. At least Brad Collins (who had nothing to do with the CRT trim) stepped up and sent me a brand new rear cowl. It really wasn't his problem, but that's the kinda guy he is.
    Apr 2002
    Wrong Irand, NY
    Quote Originally Posted by sschefer View Post
    Very Good Info
    Most likely a bad switch or loose wire,
    Relay is toast for sure if its clicking,
    You can check by swapping it with the other relay
    there should be 2, they are both the same
    Formula 260ss 496HO
    Bender Clan Member
    Apr 2009
    The Peoples Republic of Massachusetts
    One more way for a Merc trim system to go full up on its own is to accidentally hit both up and down buttons at the same time.
    NRA Life Member
    O
    ne Big Ass Mistake America
    58' Farmall Cub
    Is that your mama's boat?
    "I said I didn't have much use for one. Didn't say I didn't know how to use it."- Mathew Quigley
    Jacksonville, Fl.
    did it rain? Ive seen the trim switch in the engine pan get wet and do that.
    Why does everyone keep calling me Richard Noggin?? My name is George!
    Just bring some aloe.....ima tan that hide.......
    Nov 2002
    peterborough
    HI. George,I like George thanks.
    free spirit / ONTARIO, CANADA.
    Jan 2006
    macon GA
    Quote Originally Posted by THE HOGG View Post
    I have also seen the same thing
Diamond Marine
