Results 1 to 15 of 39
Thread: The carbon viper
05-19-2010, 10:51 PM #1
The carbon viper
Ok I started a recore thread last year but stopped posting on it because I thought there were enough of them. At this point in my restoration I think I have something a little different that others might be interested in.
I'm a marine tech by trade and so far from a body man that it's funny. The gel on my viper was so cracked up that I was told the best way to redo it was to sand it all off. I did it to the bottom and after all the sanding I didn't want to do it to the top so I thought of doing a wrap. I couldn't think of a cool design other than carbon fiber but I don't like the fake carbon so I figured go to the next level and use real carbon.
I talked to the guys at Express Composites and told them what I was thinking of doing and they weren't sure hoe it would turn out but gave me some pointers. Well it's almost done and it is actually just about how I imagined it would look.
I started by sanding the gel with 240 to get the loose metal flake off then 36 to get a good bite with the new gel.
Then I rolled a layer of black gel over the old stuff. At this time I saw how all the cracks showed up in the new gel.
Once that cured I figured out it would be critical to get the carbon on straight witch was a pain to say the least.
I could only find 50" wide carbon so I used 2" carbon tape on the body line.
The center of the dash is about 52 and 1/2 inches so it's not perfect but close.
The sides with carbon.
I found it hard to cut the carbon until I let it cure and cut it with a cut off wheel on a dremil then peeled up the tape. I then layed the 2" tape up agenst the red so with the clear on it there wouldn't be a bump.
After that I layed the black on the outside. This is what I'm not all that pleased with, it's just too plain.
I cut out the splash well and made a flat deck and covered that in the same gray carbon as the 2" tape. I then rolled enough clear on it so I could sand it and not hit the carbon. At this point I needed some help from a professional and had it sprayed last weekend.
I still need to sand it one more time, then It will get a automotive clear for the uv protection.
All and All I'm pleased with the outcome, heck a mechanic did it in his garage and it was my first time doing anything like it.Chet Olson
05-20-2010, 03:24 AM #2
samari that is awesome well done what resin did you use to wet it out ? another way to finish carbon is to use surfboard finishing resin pour it on and use a squgee then go through the grades and buff it up have been thinking about doing some more carbon work my self but need to get off my arse .
05-20-2010, 04:18 AM #3Screaming And Flying!
- 14,753
- 381
- 1304
- 5602
- 11033
That is really different and original.... Looks cool.. It's getting harder to come up w/something original. Enuf hard work and determination and anything you can envision is possible. I bet in person it's impressive....Show more pics...
05-20-2010, 06:36 AM #4
05-20-2010, 07:30 AM #5
That is really original, and very cool. Is it done in epoxy?
I agree with the surfboard resin idea, has UV protection, and can be polished to a mirror finish.Living in the Freedom provided by Bud Conner and his fellow warriors.
05-20-2010, 07:34 AM #6
Another thing you might want to try, is 1/4" pinstripe on the raw edges of the fabric you don't like, should make it much neater.
05-20-2010, 08:57 AM #7
05-20-2010, 09:03 AM #8
very cool!!
05-20-2010, 12:52 PM #9
Thanks guys, I was a little sceptical about posting it here but I think so far it turned out scream and fly worthy.
I used polyester resin and gel, it's not ment to be structural but it did stiffen it up a bit.
Thanks for the tip on the surfboard resin, I'll look into that tonight.
The boat will be powered by a 2.4 200 with a little help from Nitrox and will mainly be used for drag racing in our club.Chet Olson
05-20-2010, 02:43 PM #10
05-20-2010, 02:56 PM #11
Chet, amazing! every time I thought all the cool stuff had already been done....
Betcha got a bulletproof deck too!OK, I got down off the porch and ran with the big dogs....kinda sore now....think I'll just lay here in the flowerbed for a while...
1976 Hydrodyne 18 I-O
1969 Allison 15R, 1973 Merc 1500 (project)
1995 Harris toon
05-20-2010, 03:19 PM #12
05-20-2010, 04:10 PM #13
Mix some Duratec clear in w the Clear Gel coat
I Go 50/50Formula 260ss 496HO
Bender Clan Member
05-20-2010, 04:18 PM #14
Hey guy l@@ks g@@d It sometimes is a real bitch doing Carbon fiber on large areas like that because the fabric has a tendency to stretch and loose its shape as far as looking and being straight . Chet , i really like the red carbon fiber and once again , very nice
05-20-2010, 04:21 PM #15
