Results 1 to 15 of 20
Thread: V-King YT re-do
    Dec 2004
    Easthampton, MA
    V-King YT re-do
    Finally almost done with fiberglass repair. New core & floors installed and sealed. Floor is going to get white gelcoat finish soon and then the rigging can begin. Happy the itchy part is almost over!
    Dec 2004
    Easthampton, MA
    Pictures
    Pics...
    Attached Thumbnails Attached Thumbnails vking yt 001.jpg   vking yt 002.jpg   vking yt 003.jpg   vking yt 010.jpg   vking yt 014.jpg
    Dec 2004
    Easthampton, MA
    More pics
    Pics...
    Attached Thumbnails Attached Thumbnails yt 001.jpg   yt 002.jpg   yt 003.jpg   yt 004.jpg   vking yt 016.jpg
    Dec 2004
    Easthampton, MA
    Pulled about 12-15 trashbags worth of wet foam out of the sponsons as well. Probably weighed about 100-125lbs total!! Stuff looked and felt dry until it was squeezed and water poured out like a sponge. Foam will stay out and never go back in. Something to look into if anyone is re-doing one of these YT hulls. Also, Craftsman multi-tool with the cutter/scraper/sanding attachments became my best friend when doing some of the finish work/foam removal. Well worth the $99 bucks it costs. Doesn't make a mess when cutting fiberglass and the scraper attachement worked great fort he foam removal.
    Cool job
    Did you redo the outer sides of the boat.In the (sponcens) hope that correct spelling.But ya know what im asking anyways..
    Dec 2004
    Easthampton, MA
    There is a small section toward the rear of the sponsons that does have core. About a 3 foot long section. I will probably end up doing that at a later date and relocating the drain holes since they were cut right into the core in the first place. I wasn't going to remove all the foam, but, I am glad I did considering how wet and heavy it was. Should've lightened it up quite bit.
    Great!
    I'll be looking forward to seeing more and more pics as you move along..
    Dec 2004
    Easthampton, MA
    Got the gelcoat on the floor done today. Getting ready for rigging.
    Attached Thumbnails Attached Thumbnails yt2 001.jpg   yt2 002.jpg   yt2 006.jpg   yt2 003.jpg   yt2 005.jpg
    Dec 2004
    Easthampton, MA
    Most rigging done, hooked it up to a battery for a test fire and everything worked as it should. Mount & plumb the tanks, finish the lower unit and polish it up. There is light at the end of the tunnel!
    longisland
    damm the torpedoes???
    Mar 2002
    waco, tx
    I enjoy these YT threads... I had one since 87, that we worked and reworked over the years. I finally "retired" it and we are de-rigging everything and it's being put away for now. We did the stringer system etc... A couple of the greatest gains we got out of this boat was flattening and filling in the pad, and notching the sides out an inch and about 6 ft forward, so they would clear the water at speed. It has definitely been a fun boat for 23 years.
    It's no fun in the sun if your boat doesn't run.
  12. #12
    Dec 2004
    Easthampton, MA
    Couple pics from today..Click image for larger version.
ID:	211871Click image for larger version.
ID:	211872Click image for larger version.
  13. #13
    Castle Rock Lake,Wisconsin
    Those YTs are so bad azz! Always wanted one. Harder and harder to find though. Good luck with her.
    1990 Hydrostream Vegas XT
    1997 225 Mariner Super Mag
    1997 Skidoo Mach Z 800 100.8 mph 1000ft.
    http://www.youtube.com/watch?v=9xkEQjMPJbM
    http://www.youtube.com/watch?v=y-_sgtIOeoo
    Lifes a garden, dig it; its also hard so wear a helmet.
  14. #14
    Quote Originally Posted by ratso View Post
    Wow Interesting.
    Can you post up more pics..
    I do like
  15. #15
    MN
    Quote Originally Posted by hydrostreamvking4m View Post
    I do like
    Me too. Looks like a real nice job and a LOT of work. Congrats.
    One question though. Why didn't you stick with a bilge tank? Planning on endurance racing or a Trans-Atlantic run?
