Page 61 of 62 FirstFirst ... 11 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 LastLast
Results 901 to 915 of 923
  1. #901
    Jun 2017
    Miami
    Attempted trying out a 3 blade 25p tempest that came with the boat before when it had a 25” shaft and it’s a dog out of the hole and spins it to 6+K RPMs
  2. #902
    Suffern, NY
    Hey Mike whats up? My 28 Promax with 1.75s hits the limiter hard at 6800 and thats at 90mph. The #s are so far off it may be both wet and tired. Sorry for such depressing input. My son ran a 30 promax on a 1.62 last weekend on Greenwood lake and got 97.1. Not sure of his RPM. Something is way off here.
  3. #903
    Jun 2017
    Miami
    Quote Originally Posted by JamesGang View Post
    I'll definitely look into checking for moisture but I also see many of you in the higher mph range are running a good amount of setback. I only have 5.5 with the CMC jackplate the motor currently sits on. Would additional setback make the big of a difference?
  4. #904
    Suffern, NY
    I have 5" of setback and so does Ben. Too much setback takes away from the rough water handling. 5 1/2 is fine.
  5. Likes tux974 liked this post
  6. #905
    Jun 2017
    Miami
    Which I’m definitely happy with. I love the rough water handling of this boat. 67 in a 2 foot chop is great in my book in this small of a boat.
  7. Likes tux974 liked this post
  8. #906
    Nov 2018
    South Florida
    My new to me, restored 22 Velocity CC with a 350 Verado
    Attached Thumbnails Attached Thumbnails A5F4BEC8-BAEC-4A65-9248-CC182FCD0F27.jpg
  9. #907
    Feb 2012
    Merritt Island, Fl
    Great looking rig!
  10. #908
    Jul 2011
    Antigua
    Quote Originally Posted by YC4 View Post
    That's a nice boat. Wish I still had mine!
    Congrats.
  11. #909
    NYC/FL/NH
    Hi guys- putting a 250XS on my 1985 22' velocity. Bought a 5.5" jack plate as well. Quick question- what is everyone running for props? Also, should I put a nose cone on it? Torque Master gear case. Thanks
  12. #910
    May 2013
    Connecticut
    1985 All original? If the transom is good, go with 12" setback if you dont plan on flying in the rough.
    I have a 1987 Regal "Velocity". 250efi 5.5" setback and have run choppers, Trophy's and a Solas 4 blade.
    The chopper was the fastest 76mph, trophy and Solas handled better but topped out around 72.
    - Propshaft height even to 1" ABOVE the pad.
    I have a Torque master with 1.62 gears so all my props are low pitch but you dont really need a nose cone unless your faster than 85ish. There's lots of other threads if you search a bit on that topic
    If your lower has the 4 holes all the way on the nose of the case your good, just plug the top 6/8 on either side of the case using a 1/4" by 1/4" long set screw from homedepot.
    Make sure you have a water pressure gauge and temp gauge.
  13. #911
    Suffern, NY
    Personally I don't like that much setback. The handling suffers in rough water. Your 5.5 will work just fine and also a 24 ProMax may be a good place to start. They work great on Velocitys
  14. #912
    Suffern, NY
    I thought you had a 1.62 but that wasn't you. Whats you ratio?
  15. #913
    NYC/FL/NH
    Just put the motor on the bracket. My hynautic steering ram is on the front and very close to the transom well. I won't be able to trim much. Any ideas? Right now im at 2.5" below the pad. Should I go up?
  16. #914
    Suffern, NY
    Quote Originally Posted by cowisl View Post
    More then likely yes, but can you post a picture of the cylinder and jack from the front.
  17. #915
    Jan 2012
    miami
    Can some one please tell me the correct height your motor should be mounted on 22 velocity , with no jackplate
