Page 36 of 62 FirstFirst ... 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 ... LastLast
Results 526 to 540 of 923
  1. #526
    Jul 2012
    S FL
    Dnelson- I hear ya about the 3l......I bought the boat spontaneously ..... I'll make do for now, I'd like to hear how the hoss compares to the hydro motive ot on my setup? Thanks for your help!
  2. #527
    Oct 2010
    Broken Arrow, OK
    My Hydromotive is the Quad IV OT its 14 3/4 dia 22" pitch. My lower is a CLE I have a '99 280 power head sitting on a '93 260 mid and lower. This same prop same pitch would likely work for you too. These are not too easy to find used, I've never run the Hoss but have seen one it would likely work pretty good.
    Jeremy Lewis
    Broken Arrow, OK
    '89 22' Velocity w/ '99 2.5L 280 Offshore
  3. #528
    Sep 2010
    long island,ny
    Quote Originally Posted by jk xlr8 View Post
    The HOSS HPD is a large ear, 3 blade with progressive rake and large tip area with a tight cup. It has a very strong hole shot bite as well as top end grip for higher motor heights and speed. It also gives excellent stern lift along with bow lift to carry a heavy boat. It looks like a chopper but performs like a 4 blade. They are all custom made, labbed and balanced and perform like nothing I can compare it to. The HPD is for larger heavier boats and offshore heavy use and what you want over the triton version. Go one pitch higher then what you think you need since it is a 3 blade. You will not be disappointed as i was surprised beyond believe after first time trying one. They are made in 14.5 and 15" dia. you might want to just call Tim at HOSS propellers and ask his opinion about your set up and what might work. He is on the site here.
    If you don't have enough 'tip' blade area you will have too much slip and it will hurt your performance. A prop is the last thing you want to skimp on if you want good performance out of a boat like yours. I'm running a HPD 14.5 X 31 in my top picture. JMOP
    1990 22' Activator Yami HPDI 300-sold-86.4
    1976 21' Challenger 2002 3.1 Yami 250 Vmax phase lll 89.7-sold
    1982 21' Superboat 300merc-87
    1990 22' Activator yami OX66 Vmax 250-84.2
    1982 30' Scarab-twin 200 Merc-sold
    1979 21' Challenger 300 Evenrude-sold
    1979 21' Superboat 200 Merc-sold-72
  4. #529
    Aug 2011
    south florida
    I'm in lake worth
    Depending on sandy
    Let's see what the weekend brings
    12 Velocity 220 - 12 Mercury 300xs
  5. #530
    Jul 2012
    S FL
    Im usually at peanut or jupiter with my other boat, I have a 30ft Pursuit Walkaround...i do a lot of fishing, I bought the velocity for my 3 yr old so I can get him into skiing and some watersports...plus Im a motorhead and have owned a bunch of speedboats over the years, can u post a pic of your boat so I recognize you next time out? thanks man!
  6. #531
    Jul 2012
    S FL
    Hey Jeremy, is your mid an os mid? You have exhaust coming out of your hub?
  7. #532
    Oct 2010
    Broken Arrow, OK
    Yes, mine is OS with the large square hole above the water line. I think its same mid you have.
    Jeremy Lewis
    Broken Arrow, OK
  8. #533
    Jul 2012
    S FL
    so does your exhaust come out of the propshaft and if so, how? I know that i need some exhaust to come out of there to aerate the prop...or maybe i need a 22p
  9. #534
    Oct 2010
    Broken Arrow, OK
    An offshore mid section has a large exhaust relief, that's why it sounds so good. However its just a relief, some exhaust still goes down and out the lower unit housing. The exhaust set up is right, you just need a different style prop allowing more aeration on the blade. When you get the right prop on it will be a big difference. The Hoss mentioned above sounds like a good one to chase if your looking used. If your going to drop the bucks and buy new contact Hoss or Hydromotive direct and explain current setup and numbers. Both are great shops with great products and will build you something that works very well.
    Jeremy Lewis
    Broken Arrow, OK
  10. #535
    Aug 2011
    south florida
    I go to peanut also.I'm on my phone now.
    When I get home I'll post a picture.
    Looking foward to meeting up to see the ride.
    Might have a prop for you to try
  11. #536
    Jul 2012
    S FL
    Jeremy- i gotcha...thought it all came out above the cav plate...never looked. I just pulled out the three plugs in the tempest, will test holeshot next week. so at 7500 with that 22p, what are you running mph wise? do you think you could get a 175lb slalom skier out of the hole with that setup?
    Limit-cool, sounds good!! the velocity might not make it out sunday, still working on jackplate and tach signal....but may swing out with the pursuit, let me know!
  12. #537
    Oct 2010
    Broken Arrow, OK
    Low 70's with my setup. My '89 rig is a little on the heavy side, fully decked out under the bow. Wife and kid love the dry storage up front though. I think my Hyromotive 22P could pull skier but have never done it. It would be a smoother pull with my backup prop. I keep a 21p Trophy copy as backup incase I hit something or need to pull heavy loads.
    Jeremy Lewis
    Broken Arrow, OK
  13. #538
    Jul 2012
    S FL
    Interesting....I am running a 24 tempest but my tach isn't working...I will have that fixed soon. I will figure all of this out soon, so with a 22p hydro at 7500 I will do low 70s..about? I think my sporty is 1.87? Is yours the same?
  14. #539
    Aug 2011
    south florida
    Here she is at Peanut a few months ago, we've added some small flags on the hull at the bow since.
    I'm still working on her set up and have had her since the start of the year.
    My focus has been all round use as a family boat ,with a full load 4 to 5 persons and 1/2 tank or more of fuel.
    My final choice for a prop so far is a Mercury Racing Bravo XS 25 pitch.
    This has allowed me good on plane time and decent top end around 76+ depending on the load.
    The motor is a 300xs with a 1.75 sport master has no problem getting to the limiter with this prop.
    My feelings are that a Bravo XS 27 or 28 will probably be the next step and will hopefully put me in the low maybe mid 80's( a speed prop is my next goal).
    I have a few props that I've kept over the years that might help you find something you like.
    I have some Hydromotive Quad IV's a 21,and a 22 which might help with your WOT decisions.(these are my old race props I 'm nostalgic about these).
    I also have a Quad IV OT 20 which I use on another boat it might give you a feel for on plane response.
    I also have a 22 Chopper small/and large diameter from another boat.
    Hope this can help.
    Roger
    PS That's my 3yr old in the boat + about 13
  15. #540
    Jul 2012
    S FL
    Sweet ride my man!!! Wished mine looked that good!!! Sounds like a plan with those props....one of those will give me a better idea of what prop i need for my setup. What rpm are you hitting the limiter? i believe my sporty gears are 1.87 and should run up to 7500 ( i think and hope anyway!! )
