Page 3 of 62 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 53 ... LastLast
Results 31 to 45 of 923
  1. #31
    May 2001
    Long island. Ny
    there similar boats just alot faster
    People say I'm lazy but it takes all my time
  2. #32
    Jan 2007
    lindenhurst
    Quote Originally Posted by hoser View Post
    Idk Hoser let me borrow your x and I bet Im not to far off....
  3. #33
    Aug 2005
    port orchard , wa
    Yea very similar,other then a few small diferences....
    21 Superboat im guessin is about 500lbs lighter,has no cuddy cabin,porta potti a differnt pad and a foot shorter...Yea sounds like there very similar.....
  4. #34
    Quote Originally Posted by aaronmt73 View Post
    Just two neighborhood boys busting each others stones.
  5. #35
    Jan 2007
    lindenhurst
    Actually I would bet that my stepp built is lighter then hoser's conehead built hull!!! Superboats have a liner which adds a decent amount of weight, there front deck is a cored deck, and also superboats are built with a matt roven matt layup which is far from light. The real difference between these boats is the design of the outside chine, the size and design of the pad, transom notch, and also the overall width of the hull. Superboats you can hang the nose way up in the air and really fly them, while my velocity will actually scrub off speed if you hang the nose up high like hoser does.
  6. #36
    Aug 2005
    port orchard , wa
    Looking at Navispeeds 01 I found some a difference on the hulls.Some time after 98 they added a small lip on the further most strake when looking at the side.From what I can tell that helped eliminate the porpoise the the 94-98 at least hulls had.I believe thats why the newer hulls can get away with vastly smaller or no trim tabs at all.On 94 to 98 at least hulls they seem to need much larger trim tabs.I have 12X9 and there not nearly enuff,the boat porpoises from 35-50 unless its trimed down or completely trimed out and wide open.What size trim tabs and on the 94 and up STEPP hulls are you running.The earlier boats are alot lighter and probably not effected as much.
  7. #37
    Nov 2007
    I have a 94 and it dont need trim tabs at all and it does not purpose either.
    This weekend I will go for a Pro ET 4 26" and a 26" Raker(with HubKit).
    I am still little curious if any one have tried a Tempest+?
  8. #38
    May 2001
    Long island. Ny
    ( level )
  9. #39
    May 2001
    Long island. Ny
    one more because the picture is cool
  10. #40
    Jan 2007
    Amityville/Lindenhurst
    no way a standard layup SB21 is lighter then a Velocity like Mikeylarge, I would say his Velocity is close to 400-500lbs LIGHTER
  11. #41
    Jan 2007
    lindenhurst
    Quote Originally Posted by RobF View Post
    Rob and I actually picked the whole back of my boat up off the stands by hand before I rigged it! She's a patatoe chip!!!!
  12. #42
    Suffern, NY
    85 with 2005 300X 88.5 GPS so far.
Name:	3.6 V8 vs 3.0 V6 040.jpg
  13. #43
    Mar 2004
    British Virgin Islands
    I dont know about the newer hulls, but the 80s hulls a factory Superboat is about 1200lbs and a factory Steve Stepp Velocity is about 1500lbs... the Velocity is a bigger than a Superboat......
    1984, 22 Velocity, Merc 225 Carb
  14. #44
    May 2001
    LI NY
    Back in the day My old boat stats where..
    1985 22" 2.5 260
    sport master 1.87
    NO set back or lift plate
    22 round ear chopper with a lot of cup
    76.5 mph @7500 rpm on a constant basis
    It was 3550 lbs with a venture single axle trailer on a scale.
    Check out that slip factor, hard to beat.
  15. #45
    Jan 2007
    Quote Originally Posted by IXtreme View Post
    1200lb superboat? Not so sure about that I think they are more like 1500-1600 lbs, full liner, plywood stringers, plywood transom
